Old 08-17-2011
cghubbell's Avatar
1977 CS27 ~ Ravat
cghubbell is on a distinguished road
Managing / Supporting Hoses
At this point I have developed a wealth of tricks for managing, protecting, and supporting wires as they snake their way around my boat. However, I'm now looking at the need to support two different bilge pump hoses where they exit the bilge and climb the hull to the loop, and then on to the through hull.
Are there ABYC best practices, or other recommendations on proper guidelines for hose "retention" devices? For some reason I'm not too keen on using zip ties with wire management clips; Seems like i ought to be using something more heavy duty.
Would appreciate tips / thoughts / or best yet - pictures!
Thanks in advance,
Chris
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Old 08-17-2011
mitiempo's Avatar
Chris
These both work well as long as you have something to attach them to. If you don't epoxy a piece of ply and attach to that.
Managing / Supporting Hoses-001.jpg   Managing / Supporting Hoses-002.jpg
Brian
Old 08-18-2011
cghubbell's Avatar
1977 CS27 ~ Ravat
Thanks Brian,
Those look much better than zip ties, and they look like somethign I can pick up at a local hardware store. I had been thinking I'd end up with some form of Epoxy & wood to make it happen. I can screw to the bulkhead where the hose exits the bilge and heads up, but the horizontal span from the bulkhead to the aft through-hull is going to need something added to the hull so a screw can bite.
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Supporting the mast for storage josrulz General Discussion (sailing related) 8 12-03-2009 05:20 PM
?Supporting boat to work on bottom?? rbaroni Gear & Maintenance 13 04-13-2007 09:57 AM
