08-20-2011
I don't discuss my member
Originally Posted by ereiss
Has anyone successfully replaced the zinc on the end of a classic maxprop while the boat is in the water without benefit of scuba? The diver I've engaged to do it is having a hard time figuring out the six hole/3 hole issue. I have a mask, fins and weight.
Any things you learned when you did it that I could benefit from?
Thank you, in advance, for sharing your experiences.
The diver you are using must be slightly retarded. It ain't rocket science.  But trying to do it holding your breath would be something of a challenge. I install Max Prop zincs all the time and I wouldn't want to try to do it without air.
If you are going to to do it that way, be sure you have the correct shape zinc (the round "universal" zinc is the safe bet) and the correct screws, as there are two different sizes used, depending on the age of the prop. Also, I have found in some aftermarket Max Prop zincs, all of the screw holes will accept either size screw but the pattern is slightly different, so only three of the holes will match the holes on the prop spinner cap. In any event, have extra screws available, as they are easily dropped. Good luck.
"Clean bottoms are FastBottoms"
