Old 08-25-2011
EricP1 is on a distinguished road
Interchangability of thru-hull transducer makes
My boat currently has a mid-90's Raymarine Tridata instrument with the depth and speed thru-hull transducers. This is probably a dumb question but if I am looking to replace those transducers with another make do I need to install new thru-hull casings/housings? To state it differently, there isn't a universal size for thru-hull transducers, is there?
Thanks,
Eric
Old 08-25-2011
tommays's Avatar
There is no one size fits all BUT Airmar for example made them for a LOT of different brands and offers a lot of of interchanges
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 08-25-2011
emoney's Avatar
emoney is on a distinguished road
You might get lucky and find at least the same diameter housing. May still need to change it, but at least you won't be making a bigger hole.
Replacing transducer- can I use this thru-hull? cdhickey Gear & Maintenance 2 07-12-2011 12:11 PM
Best in hull transducer Waltthesalt Electronics 3 03-25-2011 09:20 PM
Through-hull transducer? flyingwelshman Gear & Maintenance 5 04-22-2008 11:27 AM
Removing Thru Hull Transducer chuck711 Gear & Maintenance 4 02-13-2007 02:13 PM
Thru Hull Transducer pixurman Gear & Maintenance 2 05-21-2002 07:04 PM
