Old 08-19-2003
KenD is on a distinguished road
Transducer Fluid
My boat has a depth transducer mounted in a pvc pipe filled with fluid,it''s not water could it be mineral oil has any one come up with a way of keeping the transducer stable.My pickup kind of bobs up and down in the pipe and I am getting strange soundings for depth not the most assuring thing in a shoal filled channel any help gladly recieved
Old 08-19-2003
ross99 is on a distinguished road
Transducer Fluid
It''s likely mineral oil -- this is the recommended setup for in-hull transducer pucks. Mine came with a base collar that is glued/epoxied to the hull and holds the oil. The twist-collar on it seals the whole thing together. In the absence of that, I''d suggest any kind of pipe/hose clamp jury-rig, and maybe some o-rings, that will stabilize the transducer and keep the oil in place
Old 08-19-2003
gwp gwp is offline
gwp is on a distinguished road
Transducer Fluid
I would remove the pipe and epoxy the transducer to the hull. Just make sure there are no air pockets in the epoxy. You can experiment to get optimum performance using a ziploc bag filled with water before gluing. Good luck...Gary
Old 08-20-2003
Transducer Fluid
What if I inverted a closed pipe end with a notch in it for the wire and put a compression spring with a little tension in between it and the transducer top to keep it in place. or will that cause a problem?I like the idea of being able to service a unit without tearing the boat apart to do it.I am considering finding a speed log that mounts on the hull with no holes to bother withreally tired of removeing mollusks from the paddle wheel.If you know of a model that works let me know. thanks kd
Transducer suspended in vegie oil. square to the bottom obiec Gear & Maintenance 7 12-20-2003 11:32 PM
Transmission & Autopilot Fluid aphil138 Gear & Maintenance 0 07-24-2003 02:13 PM
Depth Transducer Question gwp Gear & Maintenance 0 07-13-2003 05:38 AM
Paddle wheel transducer dargiem Gear & Maintenance 14 01-21-2003 06:02 AM
Transducer in steel hull davejean Gear & Maintenance 0 11-07-2000 08:55 AM
