08-25-2011
HOT water, close to boiling if you can, heat gun or hair dryer, then a torch or equal for heating up the hose, all work. Torches get touchy with the hose you have, down low and farther from the hose the better so the hose does not overheat and distort. I use torches for the heavy plastic wter hoses going into homes. I've also seen some take PVC glue on the end, and light a match, but this is frowned on by some jurisdictions........
have not used peanut butter, but have used other slippery items like oils to help slip things over barbs.
Marty
She drives me boat,
I drives me dinghy!
