08-26-2011
Senior Moment Member
Originally Posted by patrickstickler
I want to add a mizzen staysail to my 33' ketch and am unsure about how best to attach the halyard block to the top of the mizzen mast.
I assumed that a fitting such as the following would be the right thing to use:
but then started worrying about how much force the rivets (monel) could take and whether something more substantial might be called for, which would be through bolted.
Suggestions?
You're right, that would be too light for the forces involved. I'd use a spinnaker block crane - it's a S/S plate with one or two bails (loops) out the front. You bolt it down to the top of the masthead fitting or weldment - whatever you have - so the two bails protrude ahead of the mast. Hang blocks from the bails and reeve your halyards. I prefer external halyards in this application. Any decent S/S capable machine shop can build one for you - it's a very simple piece.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
