Old 08-28-2011
oomfh is on a distinguished road
Cleaning hull without removing wax
Applied two coats of Collinite Paste Fleetwax this spring. Even after giving the entire deck and cabin top a complete wash down, we still get black streaks down the side of the hull . . . assuming it is coming from coal fired power plants.
We go over the hull with a soft bristle brush after we've sail - but by about mid-season the streaks need something stronger.
What product do you use clean your hull that won't remove the wax?
Old 08-28-2011
jrd22's Avatar
Courtney the Dancer
I've been using Imar, heard about it in Mainsails thread on buffing and polishing, and it seems to be easier on the wax than others.
Yacht Soap Concentrate
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 08-28-2011
hellosailor's Avatar
Suggest you call Collinite, they're fast to answer the phone. Generally "car wash" boat wash or aircraftr wash products are designed to clean without removing the wax, while other soaps are more aggressive.
Soot marks might be from a coal plant, or unburned jet fuel if there's a flight pattern over you and near an airport. Sometimes there's no way to deal with that except repeated washing and rewaxing.
Hull cleaning/streak removing josrulz Gear & Maintenance 18 05-11-2010 07:52 PM
removing a thru-hull, any advice? RetCO Newport 5 12-03-2009 07:06 PM
Removing the deck from the Hull for a refit wesramm Gear & Maintenance 12 09-18-2008 06:10 PM
Removing Thru Hull Transducer chuck711 Gear & Maintenance 4 02-13-2007 02:13 PM
Removing Thru-Hull Fittings Dan Dickison Gear and Maintenance Articles 0 04-23-2002 08:00 PM
