08-29-2011
Proper installation of sea cocks
My Bristol has about 10 Wilcox-Crittenden "Seacox" and I need to start replacing them, as they are all either too stiff or leak (or both!) Well, the problem seems to be that if you tighten them up enough not to leak, they don't turn!
I was looking at the instructions for installation of Groco seacocks, and they say that the base plate should be bolted through the hull, or at least to a base block of wood, don't just rely on the through-hull mushroom.
None of the "Seacox" Bristol installed are through-bolted (despite having the holes in the base), and neither does a newer Groco one for the engine intake, installed by a reputable boatyard 2 years ago. There's a huge amount of white goo around it though.
So my questions are, how are seacocks normally installed. Is the through-bolting necessary, and if so, why didn't Bristol or the boatyard do it? Time & cost? I would expect the boatyard at least would be only too happy to bill for the extra labour involved in through-bolting the seacock.
Bristol 31.1
