Excessive mast rake (with pic)?
Hi everyone,
I recently bought a 27ft cruising sailboat (moderate/heavy displacement, long keel, sloop rigged). The mast is deck stepped, and it is not resting flat on top of its step, but leaning backwards. I have tried easing the backstay and tightening the forestay as much as possible, but that did not made any noticeable difference. I have attached a picture to help illustrate the issue. The measuring tape shows a gap of about 0.5cm (0.2 inches) on the forward section: http://i53.tinypic.com/28wncsm.jpg How much of a problem could this be? Is it something that is normal/acceptable, or does it have to be sorted out as quickly as possible? Many thanks :) ! |
Did you have the boat surveyed before buying? I would certainly have a rigging expert look at this. The base of the mast should be flush with the deck.
captainrizzo,
Thanks for the answer. The survey did not highlight any problems with the rig. I took the mast out this winter to check everything was OK at the top, and to replace a few things. I can't remember if it was like that before un-masting the boat, or if it was OK and the mast was not put back correctly. The forestay is as tight as the furler will allow, which means that I know of no other way to increase the tension forward. The whole rig was replaced about 10 years ago, maybe the rigger cut the forestay a bit too long? I don't know.. |
What type of boat?
Some boats have rake. It can be fast... |
It's a Halcyon 27, english designed and built in the early 70's.
The mast was changed by the previous owner, so not part of the original boat. |
Irati,
Ignoring the mast step plate for a moment, what's the actual orientation of the mast in relation to vertical? You may have a mast that's oriented fine, but have a little compression problem under the step... Hard to assess without knowing all the variables. |
The prime affect of mast rake is on weather helm. Does the boat display moderate and manageable weather helm? If so, all other issues being equal, the rake is probably right, if no, then the rake may be a problem.
| All times are GMT -4. The time now is 02:52 AM. |
SEO by vBSEO 3.6.1
