08-31-2011
Senior Moment Member
Originally Posted by poopdeckpappy
That's what I would do, grind, get some poly filler and spray a new finish on
not as easy as it sounds but doable and a fun project
Pappy is right. Putting teak trim up would require pretty advanced woodworking skill to make those large radius corners and it would only cover up that exposed core, which WILL get wet sooner or later (probably sooner since it is a hatch).
It's a LOT easier if you remove the hatch first - it prevents grinder marks on the hatch, gives you complete access to the surface, allows you to work from above (downhand) and you get to ensure it is properly sealed when you remount it. Consider the quality of work done on the original installation - do you trust their skill at caulking?
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
