08-31-2011
Senior Moment Member
Sabreman has the solution for through-deck chainplates (and all other deck hardware). The "trough" he refers to is essentially a rectangular countersink. I have found through experience that countersinking all bolt holes will allow a small reservoir of sealant to collect and act as a recessed O-ring when the fasteners are tightened down. Cutting, sanding, filing or grinding a small facet around the opening for the chainplates will have the same effect, trapping a rectangular "O-ring" of sealant under the cover plate.
I've been doing this for years and never had a failure.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
