09-03-2011
Should not on a steel boat. If the engine has a flexible coupling the shaft and prop are isolated. Alternators and starters are available without the case as part of the ground system. If this is done the engine block isn't part of the ground.
The other solution is to isolate the engine circuits except when the engine is running and this is easier. When not using the engine both positive and negative are isolated with 2 separate switches.
Any terminal blocks or switches can be attached to a material like plastic and it attached to the hull for isolation.
Brian
