09-04-2011
We have an 11 1/2 foot AB aluminum RIB.
Most of the floor (or should I say sole) is a flat double bottom, but the extreme forward is single bottom, so is a v'ed bottom open area. We kept the 3 gal tank up there, but it would tilt over and leak some gas, if close to full. And one was always trying to step beside it to climb over the bow. It was really kind of dangerous.
So I built a sort of box with a bottom that fit the bow area, that the tank fits in. It was a close fit, so I didn't have much room to play with. I glued some closed cell foam that I had to the top of it to make a nice seat as well as giving good traction when using it as a step to climb over the bow.
But why stop there? The rowing thwart/seat was always getting in the way when moving about, so I made a removable stabilizing base for the front end of the box so that the box can be moved to a position for rowing, or under power with only one on board (though I rarely go to the trouble). Now the original seat is in the attic, out of the way.
I may have some pics that I can get to in a few days, or can take some the next time at the boat.
But it all works well, and keeps the weight and clutter of the fuel tank up forward where it belongs.
