Like Tree1Likes
  • 1 Post By CharlieCobra
Old 09-05-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Keel Bolt Torque
I have a question for the members - does anyone know any engineering rules that would allow calculating the torque required on a given keel bolt or bolts?
The reason I ask is that the general attitude seems to be "more is better", "crank on them until they squeal", or "put a pipe on a breaker bar and pull until the suckers scream for mercy". I've never seen anything much more technical or sophisticated than that.
I've always understood that a specific torque is required in order to stretch the bolts properly to achieve proper clamping force - this varies with the size of bolt, material it's made of etc.
Also, high torque is required to compensate for powerful, high frequency repetitive or rotational forces - engine cylinder heads, road wheels etc. not static loads where the bolts are only "locating" the parts in question.
To my eye, a keel falls somewhere in between these extremes - repetitive flexing forces from the boats motion but not really high frequency. Considering that such highly loaded fasteners like cylinder head bolts, connecting rod bolts, main bearing caps etc. are only torqued to values like 80 Ft/Lbs, I don't understand the need for keel bolts to be run up to 150 - 300 Ft/Lbs, especially considering they are generally stainless steel which I understand compares to, at best, a grade 3 fastener. It seems to me that these extreme torques are only going to crush the hull material, overstretch the bolt and/or risk galling the fasteners.
Anybody?? Charlie Cobra??
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 09-05-2011
Don Radcliffe
donradclife is on a distinguished road
Size matters.
Steel Bolt Torque Specifications Table - Engineer's Handbook
Old 09-05-2011
SloopJonB's Avatar
Originally Posted by donradclife View Post
Thanks for the table. It certainly does but those tables don't specify the usage - it isn't the same for all situations. Also, I noted the S/S torque specs for 3/4" bolts are spec'd in INCH pounds. That would put my keel bolts at about 120 Ft/Lbs.
Old 09-05-2011
I think you also need some info as to what the hull/keel sump structure can take in terms of compression as you torque the bolts - so taking the data from the tables for the thread/size alone may not be the whole picture..
1984 Fast/Nicholson 345
Old 09-05-2011
tommays's Avatar
Most every boat i have seen is SOLID glass in the keel bolt area except some older Catalinas that never got the upgrade
BUT i think most boats have a user group or info available someplace on the original torque level
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-05-2011
BELLATRIX1965's Avatar
Maine Member
BELLATRIX1965 is on a distinguished road
Yes, size DOES matter! And material type, and thread type (fine or coarse) - AND is it dry torque or wet torque? Dry torque is what it sounds like; wet torque refers to anti-sieze or oil applied to the threads AND under the head of the bolt or nut. Due to the reduced friction, a bolt torqued wet is under much more strain than the same bolt torqued dry.
If you can, I'd contact the manufacturer of your boat and get their recommendations.
Old 09-05-2011
WDS123 is on a distinguished road
It is possible to crush solid glass by over tightening keel bolts.
The link posted above is a good layman's guide
Old 09-05-2011
SloopJonB's Avatar
I would but they went out of business 30 years ago.
Actually, I used some specs that match up pretty well to the posted chart. I posed the question out of mere curiosity because I read & hear so many things like the "techniques" in my OP rather than anything technical or scientific - so unlike my other passion - cars. There everything is spec'd to the Ft/Lb.
Old 09-05-2011
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
We did 300 Ft Lbs on 1 1/4" SS with anti seize on the keel we did. The bolts are rated to 500. This was after talking to the designer about it.
SloopJonB likes this.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 09-06-2011
PopeyeMike is on a distinguished road
I replaced the keelbolts on my Pearson 26 this past spring. I torqued the bolts to something near 80 ft-lbf. Dan Pfeiffer's P26 web page has all the details on the bolt size (3/8" - I think??) and torque for a P26.
Overtorqueing (is that a verb??) can damage the bits between the nut and bolt (i.e. fiberglass and any filler material), and serves no purpose other than to reduce the "additional" load capacity (i.e. load beyond the load created by torquing the bolt - like holding the keel in place).
25' Mirage Keel Torque Setting Patricia-David SailNet FAQ's 1 06-29-2011 10:45 AM
Yanmar 2GM20 F Exhaust Riser bolt Torque specs ronsunni Diesel Engine Forum 0 10-08-2009 01:59 PM
MacGregor/Venture Keel Pivot Bolt Torque? CHOCKfullOnuts222 Gear & Maintenance 0 03-31-2009 10:22 PM
Keel bolt torque specs gknott Gear & Maintenance 2 01-19-2009 08:05 AM
Keel Bolt Torque GordMay Gear & Maintenance 2 05-07-2003 09:34 AM
