09-05-2011
ancient mariner
on a 64 ft topsail ketch i was a 4% owner. i took an oil cooler & steam cleaned it out. i piped the engine antifreeze from from below the thermostat with a ball valve to shut it off, through where the oil went around the tubes , and back to the engine above the thermostat. i put a tee & ball valve between where the sea water leaves the heat exchanger & the muffler. i hooked it up to run sea water through the tubes in the oil cooler with a hose that ran through the bilge to the cockpit. i would pull the hose out and open the valves with the engine running & had warm water to shower in the cockpit as long as we wanted.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
