09-06-2011
Lies about her age
That type of heater uses high amps to heat the water. I would ck the heater amperage draw plate. I'm guessing it's 120 volt at 15 amps. There could be a short in the heater itself causing the GFCI to pop also. The heater may have been turned on when by chance the water pump was off and the lines had air in them. the element will go poof in very short order if it's not immersed. Does it operate on a non GFCI circuit? I'm betting the heater is shorted, most likely the element.
