Old 09-07-2011
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
Another what is this?
I was thinking this is a tell tale type thing? Am I right? I have them on my port and starboard shrouds.
Thanks in advance guys!
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Old 09-07-2011
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
Not sure what it is called but I suspect it's job is to help prevent the halyards from getting "stuck" on the wrong side of the shrouds. An ongoing and irritating issue with my Contessa 26. I stand corrected but I believe it should be mounted where the shroud meets the spreader.
John
Old 09-07-2011
BreakingWind2's Avatar
BreakingWind2 is on a distinguished road
They are rollers to assist with the sail travelling over the shrouds when tacking.
Old 09-07-2011
Do they work? I've not seen them on other boats...
And yes, they are down by the spreaders.
S/V Frida
Old 09-07-2011
jppp is on a distinguished road
Had them on my Hobie 18 back in '80
'79 Camper & Nicholson 303
Sunfish
Dyer Dow
Old 09-07-2011
You usually see them on the lifelines up forward to assist where the genoa passes over the lifelines, not on the shrouds.
Cant personally attest to whether they work or not but I see them all lot so must be some value to them.
Old 09-07-2011
Cool, thanks for the input!
S/V Frida
Old 09-07-2011
rugosa's Avatar
rugosa is on a distinguished road
It's a shroud roller, made by Davis or one of their competitors, should be mounted near spreader
Old 09-08-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Correct, designed to keep the leach of an overlapping sail from coming in contact with a spreader tip. Davis also made (may still make) split shroud rollers that allow the clew of a sail to roll over the shrouds when tacking. I've got one on my Baby-stay but cannot find any large enough for our shrouds (and I'm not fond of the home made PVC pipe versions!).
Old 09-08-2011
hellosailor's Avatar
Might be called a shroud roller, but we always called them genoa rollers or headsail rollers. Installed on the upper lifeline, not the shroud, so a honking big headsail pops over the lifeline easily. Less wear on the sail.
