-   -   Making Your Own Sails (http://www.sailnet.com/forums/gear-maintenance/7849-making-your-own-sails.html)
Eligabiff 08-25-2003 11:49 AM
Does anyone have any expierence with making their own sails? I''m looking for a suggestion on where to start with this. I''d really like to know if there is a pattern available. I''ve seen some information online about kits but all the links I have found are old. Thank you!
mcain 08-25-2003 12:24 PM
Sailrite has kits available. They sell kits, materials, cloth, sewing machines, etc. We have not personally made a sail, but we have made a custom bimini using their materials and sewing machine. They were very good to work with.
joub 08-25-2003 07:26 PM
Making your own sails from a sailrite kit is a practical endeavor if your boat is less than 25''. Larger boats require heavier and larger sails. The heavier material and larger bulk makes it difficult to sew on anything but a heavy duty machine.
A first timer trying to cut his/her own sails and sew them is pushing the odds. The result will likely be less than optimum and disappointing.
I made a genoa for a 23 footer I had at one time. It was a sailrite kit and was good quality and the instructions were very good. However, the machine I had to use at the time was really struggling to sew though multiple layers of material. Trying to feed the rolled up sail through the machine and sew a straight seam was a real challenge.
Just my experience.
Jim
flicker 08-26-2003 07:30 AM
If you look under "Sail Repair- sewing machines" (last post 08-13-03) in Gear & Maintenance, you''ll see a lot of discussion about sewing machines. I think the gist is that a proper choice of needle and a heavier fly-wheel will help your machine punch throught the layers of fabric.
Chas
aflanigan 08-26-2003 09:43 AM
You are looking for a suggestion on where to start.
Don Casey, the old boat guru, wisely suggests starting small and modest. Take his advice.
1)Find yourself an old homemaker''s electric sewing machine with a nice, heavy mechanism and flywheel; an old Kenmore or Singer, for example (it should feel too heavy to use as a doorstop). Take it to a shop to have it cleaned and reconditioned. Preferably a shop where the repair person is elderly. They should smile warmly when you heft your old gem onto the counter, and concur in your intent to use it for sailmaking (the fellow behind the counter at my neighborhood shop told me with amusement that every spring he gets a raft of boat owners bringing their wive''s late model sewing machines in for repair after trashing them trying to do sail work on them).
2. Find a small, simple project to start with. A wind scoop for your forward hatch; a sail cover kit from sailrite; add some reefing points to your mains''l, or redo (beef up) the reinforcing triangles at the head and clew of your existing jib or main (either of these will give you a really good idea of whether your machine will handle sewing through several thicknesses of dacron capably).
3. After doing 2 above, or if you know your way around a sewing machine well enough already, and are of a mind to upgrade your boat by adding roller furling, you can do what I did: Take an existing sail or buy a used one, and convert it for roller furling. Sailrite has the kits and instructions; it typically involves shortening the luff by cutting off a triangular strip from head to tack, repositioning the head reinforcement patch, attaching a special luff tape for the furler extrusion, and attaching a sacrifical (sunbrella) cover to the leech and foot of the sail so that when it is rolled, the dacron is protected from UV.
4. If you are really intent on trying sailmaking, start off by making a storm jib for your boat. Lower material cost, easier to cut, lay out for seaming, easier to fix mistakes if the shape comes out wrong, etc.
Once you''ve got your machine and have a few of these starter projects under your belt, you''ll hopefully have an appreciation of the fun and challenges involved in making your own set of sails.
Happy stitching,
Allen Flanigan
Alexandria, VA
