09-08-2011
Thanks Captainmeme, that's a helpful manual. Here is the schematic from p 56. Now I see where I went wrong. This is from the trouble shooting guide I was looking at from a Yanmar workshop manual.
Tachometer Gauge
To check the tachometer gauge unit, proceed as follows:
1. Disconnect the red/black and black wire leads from the
tachometer. With the key switch ON, measure the voltage
betWeen the two wires. There should be 10-16 volts (battery
voltage). If not, detennine the cause.
2. Disconnect the orange and blue/red wire leads from
the tachometer. Run the engine. Measure the alternating
current voltage between the orange and blue/red wire
leads. The voltage reading should be at least one volt.
3. If the voltage reading in Step 2 is less than one volt,
check the wires and connections and check the sender as
described in the preceding section.
4. If the voltage readings in Steps 1 and 2 are satisfactory,
replace the tachometer.
I confused the red/black for the bulb with the red and black leads. I'll check it again in the morning.
wiring diagram_1 by chuckanastasia, on Flickr
I appreciate the help!
Best,
ChuckA
Twitter: @CoastalCafe_NE
