Self-Tailing Winch - SailNet Community
Blogs
Old 09-08-2011
sailing320's Avatar
sailing320 is on a distinguished road
Self-Tailing Winch
How often should I clean and service my self-tailing winches? What is the best product to use for lubricantion / grease? I have Lewmar's on my boat.
Old 09-08-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
In Florida, and if you sail very often, at least annually. We have 12 very large winches and it is a PITA but I do one a month which takes about 45 minutes each with Mineral Spirits or Kerosene followed by Lewmar Winch Grease for the bearings and shafts and 3-in-1 oil for the pawls and springs. Not such a big deal...
FWIW...
Old 09-08-2011
Gary M's Avatar
Gary M is on a distinguished road
It depends on how much and for what purpose you use your winches. An active racing boat will do them at least once a year. Some winches however have likely never been done.
You can buy Lewmar grease at any marine store and you will also need a light oil for the pawls. You should also buy a package of pawls and springs before hand as you will need some.
I would suggest getting a copy of the Lewmar manual on overhauling their winches. Likely available for free on line.
It is not difficult to do them, self tailers take about twice as long as non self tailers which take me about 15 minutes to do once set up for it.
Have fun
Old 09-08-2011
rugosa's Avatar
rugosa is on a distinguished road
Barient parts
Is there a source for Barient small parts like pawls and springs?
Old 09-08-2011
transmitterdan is on a distinguished road
Barient parts
I think WM has them still. Check West Marine Boat Parts, Boat Accessories, Sailing Gear and Boating Apparel and search for barient.
Regards,
Dan
Transmitterdan
1995 Valiant 42
Old 09-08-2011
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Exclamation
I have Barient 22s on T.B. It turns out Lewmar pawls and springs fit Barient winches. Take an example in to your local marine store for comparison. Other parts have no equivalent. I needed to replace a bearing in 2009 and, after doing my homework, ordered them from Australian Yacht Winch. The have a huge stash of Barient parts. In fact, they were the only source I could find. Shipping to the USA was expensive and took a while.
It looks like they have survived the great global recession. You can write them at "Australian Yacht Winch Co." . They graciously answered several rounds of questions before I bought from them, which was encouraging. The address and phone info I have in my old e-mails are below.
AUSTRALIAN YACHT WINCH
4 Narang Place, St Marys NSW 2760 Australia
Phone: +61 2 9623 2448 Fax: +61 2 9623 2265
Regards,
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 09-09-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
My experience is that they fit but are not identical so you must change ALL of them to Lewmar. I found the pawls to be a hair shorter - just enough that only one pawl would bear the whole load.
Check the thread "winch trouble" - it's 2 or 3 pages in on this forum. Lots of good info.
"There is nothing, absolutely, nothing half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 09-09-2011
SloopJonB's Avatar
Gary, why do ST's take you twice as long? Once the barrel is off I find them to be just the same as standard winches.
Old 09-09-2011
puddinlegs is on a distinguished road
Barient pawls and pawl springs are not identical to lewmar. Lewmar now markets Barient specific spring/pawl repair kits. Barient parts proper can be found here:
HUTTON-ARCO Yacht Winches
To the OP, once a year usually works. If you're somewhere that is exceptionally wet, perhaps twice.
Old 09-09-2011
Thanks for that insight, SJB. I change sets of things rather than individual pieces so I didn't notice the difference. I always figure if one is worn or damaged, the rest aren't that far behind and I'd rather do the maintenance once.
I looked up Hutton Arco Yacht Winches after PuddinLegs' recommendation. They use the same address and telephone number as Australian Yacht Winch gave me a couple of years ago. I presume they reorganized and changed their name. I hope they are thriving since they still seem to be the sole source left for many Barient parts.
Tom
T. P. Donnelly
Pasadena, MD
Self tailing winch danger centaursailor Gear & Maintenance 10 05-02-2011 05:55 PM
best old self tailing winch dohenyboy Gear & Maintenance 1 07-19-2010 04:11 AM
Self Tailing Winch, size ? Question jasper Gear & Maintenance 5 08-25-2009 07:11 AM
Lewmar Self tailing winch line size don712865 Gear & Maintenance 9 07-22-2008 04:53 PM
Sail Track or Self Tailing Winch? johar Gear & Maintenance 6 01-25-2003 12:06 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
