Help on cheap Fiberglass repair on boat - Page 2 - SailNet Community
post #11 of 13 Old 09-11-2011
One of None
deniseO30's Avatar
If you don't plan to fix the little boat right.. is this an indicator of how you will care for a larger boat should get one? The little boat may be worthless, but if you are going to repair it. geeze do it right.. Before you do any repairs to the keelson at least power wash the dirt out!
My last project!
deniseO30 is offline
post #12 of 13 Old 09-11-2011
Both ends are pointy.
junkrig's Avatar
Denise, darlin', I bet power wash would take the whole keelson out!
Seriosly, though: no Bondo, no polyester resin. Some fix-rot epoxy until it won't suck up any more, then a (one should do) layer of glass tape over that, then mount the mast step either with screws (if the keelson took up enough epoxy) or fix it down with more tape and epoxy. At last that way if you do give it away the next guy won't inherit a worse mess than you did.
S/V Seablossom Nor'Sea 27 with modern junk rig.
Just because I like it.
junkrig is offline
post #13 of 13 Old 09-11-2011
overbored's Avatar
Originally Posted by Captainmeme View Post
Do it right with epoxy. The loads on fittings even on little boats are enough to inflict damage to you if there is a failure. Whats an eye worth?
I agree, if the rig fails someone could get hurt. if you are not going to fix it right then you may be putting your family at risk.
"GOLD RUSH" PRINDLE 16
overbored is online now
serious fiberglass repair- help hertfordnc Sailboat Design and Construction 11 07-09-2009 11:21 PM
Fiberglass Repair SollaSollewSails Gear & Maintenance 4 12-18-2008 03:51 PM
Fiberglass repair the right way? davidpm Gear & Maintenance 31 12-08-2007 02:15 PM
B&K Fiberglass Repair brak Gear & Maintenance 0 05-16-2007 02:48 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
