Old 09-10-2011
cooltec is on a distinguished road
Pearson 32 Missing Rudder
Owned this 1982 Pearson since 1986. Sailing back from Erie Islands to Toledo, heavy seas on the beam, double reef. Lost steering, checked internal steering linkage and rudder post OK. Towed to Toledo. Went swimming, no rudder. Rudder post intact, stainless rudder plate (about which the fiberglass rudder is molded) weld torn and plate bent. Any known similar failures and/or replacement sources?
Old 09-10-2011
mitiempo's Avatar
You could try this company NewRudders.com » About Us
They have standard rudders they produce as well as do custom work. I think they make more rudders than any other company.
Brian
Old 09-10-2011
stam22's Avatar
Windwalker - O'Day 34
stam22 is on a distinguished road
You could try Rudy at D&R Marine in Assonet, Ma. (508)644-3001. He stocks a lot of Pearson parts and some rudders.
Old 09-10-2011
hellosailor's Avatar
Congratulations, cooltec, you've had a conventional rudder failure. There has been water in your rudder for some time, possibly 10+ years, which rusted the armature until it snapped. Al it takes is a hariline or pinhole, and time.
About five years ago my friend had a long and unsatisfactory experience with Foss Foam of Florida (aka newrudders now?) and I wouldn't touch them with a ten foot pole. the job took more than twice as long as predicted, rudder was sent back and remade, and still came back not working like the old one. Boat lost almost three months out of the water, cost wasn't cheap. Folks were very uncommunicative. On a 0-10 scale, I'd rate them zero, but that's just one personal observation from one transaction.
If you locate a used rudder--check it out carefully. If there's any sign of moisture inside, as there often is with old rudders, it needs to be opened up and rebuilt or it WILL FAIL IN TIME. I've heard there are a couple of "rudder shops" in the US who do good work, no experience with any of them personally, no names on file. But Foss...I'd burn the boat first.
Old 09-13-2011
Great posts, thanks to all. Will check out the sources.
Unable to locate original rudder design drawings or specification for the 1982 Pearson Bill Shaw design. Appreciate any other thoughts on sources. thanks, Ron
Last edited by cooltec; 09-14-2011 at 03:22 PM. Reason: Additional Information Request
Need a rudder for a 1980 Pearson 26 sampilot Gear & Maintenance 7 01-22-2011 01:38 AM
Pearson 30 rudder bushings johnp30 Gear & Maintenance 2 02-13-2010 08:09 AM
Droping the rudder on a Pearson 33-2 Sabre66 General Discussion (sailing related) 2 05-19-2008 01:05 PM
Pearson 30 Rudder Repair PatJordan Gear & Maintenance 7 09-19-2005 01:34 PM
need rudder for pearson 26 windprop Gear & Maintenance 2 03-03-2004 07:51 AM
