Old 09-11-2011
kcbillb2's Avatar
kcbillb
kcbillb2 is on a distinguished road
Tabernacle Replacement
The problem I ran into last spring raising the mast for the firs time on my Starwind 19 was that the sheetmetal tabernacle had been mangled (to put it politely) by one or more previous owners.
My plan is to make a new tabernacle out of Aluminum channel stock and shim as necessary to get the necessary internal width.
Anybody else have this problem and if so, how have you solved it?
kcbillb2
Kansas City
1986 Starwind 19
S/V Transmogrifier
1974 Mutineer 15
Old 09-16-2011
1977 RK-21
pbpg is on a distinguished road
I had a deck plate which would probably be under the tabernacle you have. That deck plate wasn't mangled so much as loose, and a little bent on one side. I found a replacement 'hinged mast assembly' at Dwyer Mast which is the same size, but which has 4 bolts instead of two. Since it's the same size, the replacement should do fine. I'd suggest seriously looking for a suitable replacement if you can spring for a little cash. Doin it yourself on something holding your very important mast is risky to you boat and your mast. Just my two thoughts. Good luck!
Cat 400 Tabernacle Mast jedowden Boat Review and Purchase Forum 0 08-01-2010 01:51 PM
Tabernacle Bent davidpm Gear & Maintenance 6 04-12-2010 02:24 AM
Tabernacle Mast Info. Requested BlueWaterBlair General Discussion (sailing related) 21 03-02-2010 02:24 PM
tabernacle for columbia 34 rastysmother Gear & Maintenance 0 02-15-2010 05:07 PM
Sealing the tabernacle to the deck. electricc0wb0y Gear & Maintenance 2 05-23-2009 02:02 PM
