Advice on scuppers & drains - Page 3 - SailNet Community
 4Likes
post #21 of 26 Old 09-20-2011
Originally Posted by rbrasi View Post
That's interesting about criss-crossing the hoses. It makes sense. Now I'm going to look at the scupper drains with the 90 degree hose connection.
Caveat is that unless the through hulls are far enough below the water line, when heeled the water will often have to go uphill to make it out the other side, so will pool in the low side of the cockpit.
Most people that I know who cross the hoses do so because of difficulty in getting the correct length hose in to provide for double clamping, something you can get around easily if the drains are 'bolt in' like the perko scuppers linked earlier. Install the hose with the scuppers removed, then slip the clamps and lock ring in, grease up the scupper end and insert it into the hose, when close install the proper bedding, and tighten up the ring and clamps. Others rebuild the system so the drains are plumbed aft and exit through the overhang or transom, which is my method, I try to eliminate as many through hulls as I can, nothing wrong with a properly installed and maintained through hull, I simply prefer having as few as possible.
merc2dogs is offline
post #22 of 26 Old 09-20-2011
mitiempo's Avatar
Merc
Whether the drains are crossed or not depends on the hull depth under the cockpit and the depth of the cockpit well relative to the waterline. On many boats if not crossed the leeward drain becomes an intake at a given amount of heel, particularly those with cockpit wells close to the waterline.
Brian
mitiempo is offline
post #23 of 26 Old 02-14-2012
i have a 78 rk21....the scuppers in the cockpit are only to drain the cockpit floor....yu lowest point in you boat is right before the center table ...yes that is true....if you put water in it it will go to that point......My name is skip and i restored one also.....got some pic if you need to see how things are......hope this helps
ewakeley is offline
post #24 of 26 Old 02-14-2012
The idea setup would be : Groco or similar quality bronze seacocks in the hull. Connect to the cockpit scuppers with quality, re-inforced hose. The reason being, if the hose fails while the boat is in the water and the seacocks are open, the boat will sink.
See here :
BoatUS BoatTECH Guides: Marine Hose
MarkSF is offline
post #25 of 26 Old 02-14-2012
Originally Posted by pbpg View Post
Thanks. If these two cockpit drains are cross-connected to the through hull drains, what drains the bilge/lowest area of the boat? An auto bilge pump?
Yes, a bilge pump. It isn't common to have drains in the bottom of the boat for the bilge, even though they might seem really handy on a trailerable boat. I used to let the self-bailers drain my Wayfarer. I could just hose out the entire bilge area and watch the dirty water pour out of the self bailers. Unfortunately I also launched the boat a couple of times with the bailers open and nearly sank it.
Trailerable and non-trailerable have different requirements here.
For non-trailerable boats, the aim is to have the least possible chance of a leak that could sink the boat. Hence all through hulls are connected with seacocks to shut them off, the drains are connected to through-hulls via seacocks so that the cockpit can be drained without any chance of filling the bilge, and so on. The bilge is a sealed area that is only pumped out by the bilge pump.
I think your boat is in the size range where some people might keep it on a trailer, and some at the dock. Hence it was built to be left on a dock.
MarkSF is offline
post #26 of 26 Old 02-14-2012
on a rk21 there isnt enough room to do that...i usee 3m 5200 very liberal on the underside with bronze thru hulls...with very thick 2 inch hose....
ewakeley is offline
Tags
balboa 20 , cockpit drains , ensenada 20 , rk-20 , scuppers
Cockpit drains theartmkr Sailboat Design and Construction 30 07-24-2013 03:49 PM
Cockpit Drains C-27 Mark1948 Catalina 2 05-02-2008 09:39 AM
Cockpit Drains KeelHaulin Gear & Maintenance 4 01-15-2008 02:35 PM
scuppers jnanjorl Gear & Maintenance 11 05-22-2005 08:56 PM
Freezing Scuppers Quickstep192 Gear & Maintenance 3 04-02-2001 03:56 PM
