Preventing sway when unstepping mast - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 09-16-2011
bljones's Avatar
Originally Posted by Izzy1414 View Post
...I have three legged guys on each side of the mast....
But not all of us have access to carnival sideshows to provide customized manpower.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 16 Old 09-16-2011
Lake Sailor
cb32863's Avatar
Oh heck BL.... I needed a good laugh this morning, thanks. I need to find a way up your way some time.... I'll bring the libations.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is offline
post #13 of 16 Old 09-16-2011
..........huh?..
Izzy1414's Avatar
It helps to marry your 1st cousin .... I lucked out when Trey and Trinity (the twins) came along.
bljones likes this.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Izzy1414 is offline
post #14 of 16 Old 09-17-2011
C&C24, Hamilton Harbour
A-frame to lift and lower the mast.
I've done the gin pole method using boom as a gin pole on my C&C24 and did not like the swaying as the mast is at the low position (boat in the water). While researching the stabilizing system i found Catalina 27 A-frame and built one for myself. The only difference in my case from the original design was that legs of an a-frame were secured to the toerails instead of chainplates. I am way more pleased with this system as the control of the mast is superb.
There is a very good video showing the system in use on Youtube
Dropping the Mast - YouTube
Hope this helps.
M
Marunio is offline
post #15 of 16 Old 09-17-2011
bljones's Avatar
Touche!
Or Threeche, as the case may be.
bljones is offline
post #16 of 16 Old 09-17-2011
I'd rather be sailing....
afrinus's Avatar
C27 A-Frame
I used the A-frame design mentioned by Marunio on my First 26 (about 30' mast). Worked great except for a small mishap when we stopped paying attention to the mast while messing around with one of the stays.
The mast started toppling over, but the winch rope caught it. We were able to hoist it back and maneuver it down without further mishap.
As you can see - just four 12' 2x4's, some line (tied at back and front cleats, and the line through the block at the top.
One thing, make sure the line is hoisted above the mid point of the mast when you untie the stays.
When I putting the mast back up though, I will first try to not use the A-frame
My mast step has a set-up that I can use as a hinge (see pic - you can see why the mast had to come down....rotten running rigging and sheaves) - I'll drill through the base, insert a hinge and then "hook" the mast step to this.
I'll prevent the mast from swaying to sides by tethering the stays with line to the chainplates or more likely through my genoa lead cars.
Pivoting the mast at the base, keeping it straight with the lines through the lead cars while lifting from the back and hoisting by the jib stay might work - I hope
If not, I'm pretty sure the A-frame will do it.
"Boat-less no more...
afrinus is offline
help unstepping mast in MA BristolJonny Gear & Maintenance 16 04-09-2013 09:11 AM
Chicago marinas for unstepping mast xort Lake Michigan 0 09-05-2011 08:44 PM
Need help in preparation for unstepping my mast. Beersmith Gear & Maintenance 37 03-11-2011 04:43 PM
Curious about mast unstepping procedure jaschrumpf Gear & Maintenance 13 04-19-2010 08:05 PM
Newbie Needs Mast Unstepping Advice jimmiebuchanan Gear & Maintenance 11 08-17-2007 03:08 PM
