Well, *there's* your problem... (trashed my wheel pilot) - Page 2 - SailNet Community
post #11 of 18 Old 09-14-2011
apogee1mars's Avatar
Make a gearbox out of metal parts. Any good machinist and a CNC machine could zap out those parts. or Adapt a all metal gearbox that is in production.
apogee1mars is offline
post #12 of 18 Old 09-14-2011
jackdale's Avatar
Originally Posted by treilley View Post
Another big advantage of a quadrant mount pilot is the ability to steer if a cable parts.
True, but I am not sure I would want to try to dock using the autopilot. The emergency tiller might be more practical.
jackdale is offline
post #13 of 18 Old 09-14-2011
rbrasi's Avatar
Originally Posted by PorFin View Post
Las Vegas comes to mind...
Hey!
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #14 of 18 Old 09-14-2011
I keep wondering about converting a wheel pilot to below decks by the replacement of the wheel drive with a linear drive ? They are both type 1 and the linear drive is rated for 2200 lb boat? Seems like it would work and a little cheaper to use existing control head etc.
"Just call me TB"
capttb is offline
post #15 of 18 Old 09-14-2011
SeŮor Member
PorFin's Avatar
Originally Posted by rbrasi View Post
Hey!
Took you long enough! Thought you'd taken a nap or something
PorFin is offline
post #16 of 18 Old 09-21-2011 Thread Starter
Rhumbunctious
patrickstickler's Avatar
So... I finally get the replacement gearbox, get it installed and everything tests out fine. Resume my trip, and #&*(@#& two days later, in a very pleasant F5 beam reach, the plastic around the clutch wheel / lever axle fails!
I suspect it was stressed during the gale, and was just waiting to fail, but @#&%*(@#& this Mk2 is a toy. I wouldn't put it on anything bigger than a 22ft day cruiser, and only use it under 10kn of wind.
I'm back at my home marina now, after 4 days of solo sailing sans autopilot, and will definitely be looking for a replacement drive of some sort ASAP.
Does anyone know how difficult it would be to adapt a non-marine (i.e. reasonably priced) ram drive with clutch, mounted to the quadrant, to the Raymarine controller? It has the connections for the Raymarine branded ram drive, but that is IMO ridiculously expensive.
Or should I consider converting from pull-pull cable steering to hydrolic, and go with a hydrolic ram drive?
Suggestions?
If a man speaks at sea where there is no woman to hear, is he still wrong?
Cruising the Baltic in 'Merihiisi', a 1979 Westerly Berwick Ketch
patrickstickler is offline
post #17 of 18 Old 09-21-2011
A New Adventurer
funjohnson's Avatar
What size boat and type do you have?
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #18 of 18 Old 09-21-2011 Thread Starter
Rhumbunctious
32.5' ~5500kg
Navico wheel pilot dvpamenter Gear & Maintenance 12 06-08-2013 11:17 AM
Smart Pilot Raymarine X5 Wheel Pilot chef2sail Gear & Maintenance 50 08-31-2012 11:05 PM
X5 wheel pilot installation????'s irwin325cc Gear & Maintenance 10 12-28-2010 07:40 PM
wheel pilot differences dvpamenter Gear & Maintenance 2 03-06-2009 12:31 AM
RAYMARINE S1 Wheel Pilot Freesail99 Gear & Maintenance 4 07-23-2008 07:04 PM
