U/V resistant/clear epoxy vs OR over top varnish - how to go? - Page 2 - SailNet Community
post #11 of 21 Old 03-28-2012
Senior Slacker
SlowButSteady's Avatar
Re: U/V resistant/clear epoxy vs OR over top varnish - how to go?
For the first parts I did on my boat (some trim around a hatch) only have about five years on them. But they have absolutely no signs of peeling, or clouding, or anything, other than a few scuff marks from normal boat goings-on. However, I don't have a lot of woodwork, so it's a pretty small sample size.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #12 of 21 Old 03-28-2012
Skipper Jer's Avatar
Thanks, puts my concerns to rest.
Skipper Jer is offline
post #13 of 21 Old 04-05-2012
Ive been researching how to treat deteriorated wood and end with a clear finish. I've been told that all epoxies have no UV tolerance and if covered with a clear finish, the system will total fail. Also that poly laid over epoxy won't set. Does an epoxy treated then clear finish need total sun protection?
M@rster is offline
post #14 of 21 Old 04-05-2012
I am going to use Ephesian varnish which is UV resistant over the epoxy.
Here is a link to west systems varnish over wood.
WEST SYSTEM | Application Techniques - Varnish over epoxy
I applied an exterior grade polyurethane on some handrails, peeled off after a year. They did look great for about 6 months, then dark spots started to show up to ruin the party.
post #15 of 21 Old 04-05-2012
RichH's Avatar
I own a Teakey and before I became a 'reformed varnish-aholic' the 'best' and longest lasting was a scheduled lay-up of various coatings:
wood encapsulated on all under surface to prevent moisture migration --->penetrating epoxy on surface to be 'varnished'---> 6-8 coats of oil based varnish (color coat) --->6-8 coats of urethane based varnish (with UV absorbing) compounds (top water seal) ---> 2 coats of Interthane (Perfection) 'Clear' as the final coat for 'ultra-gloss'. The MOST important is the UV filter to prevent destruction / weakening of the surface wood cells. Second most important is to seal/encapsulate to prevent MOISTURE migration through the wood. Those two issues are what destroys the bond between the wood and the 'varnish' and causes 'lifting' and 'the black staining'. Even with such a 'hodgepodge' of layers/coatings ... the average 'best' I could get out of them was 5-6 years and then had to do a total strip-down --- ugh!
For simplicity and still for a close to 'varnish-like' coating is simply to use a modern 2 part base + 2 part 'clear' ... and typically get 10-12 YEARS with simple quick 'clear coating' every 2 years ... and a quick power-buffing with 3M "Perfect-it" in the 'between years'.
My preference for the 'modern' coatings is Honey Teak (signaturefinish.com), then Bristol Finish, etc. These are quite easy to 'repair' if you dont let water penetrate into the wood. If you want a 'museum grade' finish that can be hand-rubbed or powerbuffed to a dazzling gloss (just like you do with a 'prime' varnish job), then I suggest Honey Teak. HT has a very high learning curve, is VERY expensive, but when you amortize over the total life, it turns out to be the very cheapest.
(I really hate CETOL, even the butt ugly 'Cetol light', etc. as its hard to repair and color-match ... and when built up it CRACKS like crazy, requiring a total strip and re-do)
If you want to see what Honey Teak looks like after 10 years ... go to: post #32 on Teak Oil vs Varnish vs Cetol
RichH is offline
post #16 of 21 Old 04-05-2012
Did you mean Epifanes? Ephesians is a book of the New Testament.
MarkSF is offline
post #17 of 21 Old 04-05-2012
Google got me, thanks 4 the correction.
post #18 of 21 Old 04-05-2012
Don't you just love spell checkers.
MarkSF is offline
post #19 of 21 Old 04-20-2012
Anyone else have negative or positive thoughts about Cetol?
I welcome emails as well.
I live in New England and just bought an old Quickstep.
The varnished areas are shot and I plan to use a varnish remover and sand these down
to bare wood and then add Cetol. Open to another product.
Also curious about Zip Strip vs Circa 1850 Heavy Body vs 5F5 stripper.
Thanks,
David
backhandslicer is offline
post #20 of 21 Old 04-20-2012
One of None
deniseO30's Avatar
Cetol "Natural Teak" is my choice after using many different makes of Varnish.
My last project!
deniseO30 is offline
Low Maintenance Brightwork: Varnish or Linear Polyurethane over Epoxy? Spencer28 Gear & Maintenance 9 09-14-2011 10:44 AM
Removing Clear Epoxy from Gelcoat labestia Gear & Maintenance 5 01-30-2011 05:37 PM
fWill Varnish stick to Epoxy? justonemoreproject Gear & Maintenance 5 11-25-2008 05:45 PM
Puncture Resistant Bike Tires wind_magic Cruising & Liveaboard Forum 18 02-03-2008 07:23 PM
Varnish, Poly or Epoxy for interior woodworking? scurvy Gear & Maintenance 14 09-17-2007 05:55 PM
