09-21-2011
Originally Posted by knothead
That is one way that they are made. They also just use thread adhesive sometimes. Either way, IMO those are inferior to welded T-bolt or eye/pin t-bolt. I have seen the threaded ones crack from the expansion of the corrosion that occurs in the interstices of the threads.
I have seen them fail completely under load in extreme cases. My recommendation would be to replace them when you do your next rerig at least and in the meantime, do exactly what you are doing. Clean them, inspect them and then soak them in something that will stop corrosion.
Then watch them closely.
Very helpful, thank you! The dye test "illuminated" some corrosion around the top of the barrel nut which is what initially concerned me. One end of the pin I mentioned is also corroded. So...it didn't really tell me anything I didn't already know (with the exception of something I will address in a separate thread). However, combined with your experience about failures, this is not good! The rest of the backstay appears to be in great condition (and is overbuilt to begin with). Your post makes me think that I can replace the barrel nut with one of the arrangements you suggest. Thanks again!
