09-20-2011
Originally Posted by knothead
Sounds like somebody might have neglected to install the halyard restrainer.
Did you experience halyard wrap?
Furlex only sells through it's dealer network which is extensive. They really prefer to have their systems installed by one of their own dealers. Did you use a rigger to install the unit? Where did you buy it?
My first recommendation would be to buy the parts from the place you bought it. But if you have relocated, you can find a dealer list on their website.
The dealers can simply make a phone call and have the parts shipped or even drop shipped.
Seldén Mast AB
The furler was on the boat when I bought it. It's got a halyard restrainer, on one of the jib halyards, but the angle fair even without it and I've never had any problems with wrap.
I replaced the luff wire and rebuilt/upgraded the lower swivel about 5yr ago. It's always been very smooth and given me no problems.
The failure is kind of a long story...
Over the last couple of years, the hydraulic backstay adjuster has failed and leaked down several times. I'm not down at the boat very often, so it could be slack for several weeks before I found the problem.
Winds are pretty strong and will make the headstay sway around a lot when it's slack, and this has caused the wire to fatigue at the swage.
I assumed that the masthead toggle would prevent this, but I was wrong...
Ibis - Albin Nimbus 42
