Old 09-20-2011
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
Stainless or regular steel for exhaust nipple?
I have to replace the 1.5" nipple that connects the engine to the exhaust elbow (Westerbeke 58 engine). Does it make sense to use a stainless nipple rather than regular steel? There is a certain amount of heat here but the combination of heat, exhaust gases, and seawater must be very corrosive.
Thanks
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 09-20-2011
We had good luck with a homemade SS one..... YMMV
1984 Fast/Nicholson 345
Old 09-20-2011
fryewe is on a distinguished road
If the engine is raw water cooled and the nipple sees seawater, bronze will give you better service life.
Old 09-20-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Thanks
Hot and corrosive is where stainless is needed most.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 09-21-2011
downeast450's Avatar
Tundra Down
downeast450 is on a distinguished road
If you can, go with ss. I replaced my hot pipe and wl muffler with ss and have no rust on the transom anymore.
Down
Old 09-21-2011
celenoglu's Avatar
celenoglu is on a distinguished road
SS is not a good material for underwater use. It needs oxygen to stay away from rust. Cast iron is the best material, you can also use bronze (not brass)
Old 09-21-2011
tommays's Avatar
I would think the engine to elbow would be dry and the water would be injected in and after the elbow no ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-21-2011
Stainless steel in a hot salt water environment under tensile stress can fail due to chloride stress corrosion, which is corrosion between the crystal grains. It manifests itself as cracks. Be careful with SS use in raw water exhaust systems.
Old 09-23-2011
SloopJonB's Avatar
Interesting - does that mean cast iron would be better (more dependable) and just live with having to replace it every number of years?
Old 09-23-2011
aeventyr60 is on a distinguished road
Schedule 40 mild steel pipe lasted me 17 years and about 4000 engine hours on a Perkins 4108
"Your dreams minus your doubts equals your net worth"
"Life favors the Fearless"
Stainless steel anchors PCP Gear & Maintenance 13 09-12-2011 05:58 PM
Stainless Steel Grades cas8100 Gear & Maintenance 14 07-22-2009 10:15 AM
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 07:59 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
stainless steel maintenance psemme Gear & Maintenance 0 12-09-2001 10:20 AM
