09-20-2011
Mango intolerant
I just bedded my portlights with butyl, there is no possible way you could hose butyl off and I don't believe it would leak if you crank it down to show a 16th of an inch or so (or less) around the perimeter (crank it down, trim with a plastic credit card corner). Use more screws as noted in the post above.
Even if it didn't work, butyl is such a snap to work with you're not really risking anything by trying it out.
