Don Casey: Paint Waterline Stripe with Bottom Paint - Page 3 - SailNet Community
 6Likes
post #21 of 24 Old 05-29-2012
SchockT's Avatar
Re: Don Casey: Paint Waterline Stripe with Bottom Paint
I always paint the antifouling up a couple of inches above the static water line. I use ablative paint so it cleans off easily. The boot stripe is not paint, it is decal. I have the remnants of the roll in case it gets damaged.
This photo is a bit exagerated because of waves and a bit of aft trim at the time of the shot.
(My son named the seal "Snokel". He hung around all weekend, and was particularly impressed with my paint job as he spend a lot of time admiring his reflection in it!)
Night_Sailor likes this.
SchockT is offline
post #22 of 24 Old 05-29-2012
Captain
Night_Sailor's Avatar
Originally Posted by asdf38 View Post
In my case, starting at the bottom it's blue bottom paint (ablative), red topside paint for the stripe, and blue topside paint for the sides. On some boats the stripe and the bottom paint don't touch but in my case they do.
I'm replacing only the red stripe at the waterline with red bottom paint.
That sound like a fine idea. Are you using ablative paint? or hard paint?
USCG 100 Ton Master
RYA Yachtmaster Ocean
Night_Sailor is offline
post #23 of 24 Old 03-05-2016
Can anyone give me advice on how to prepare the surface of my topside boot stripe to be covered with ablative bottom (antifouling) paint?
The boat's waterline is where it should be (a good 2" above actual waterline with boat loaded), but wave action gets well up onto the bootstripe, creating a perfect environment for gunk to grow. I want to raise the bottom paint up to help with this (the bottom paint I use is quite good at stopping all growth, including plant-like gunk).
In my ideal world I could simply clean and sand the boot stripe and roll on the bottom paint. But something tells me that I need to do more, specifically use some kind of primer, so that the bottom paint sticks properly. The bottom paint instructions aren't clear about what to use (they say use "suitable existing antifoulings and primers," which is not very specific!). Can anyone suggest what I should do? I am hoping that the reply does not involve any white primer. The bottom paint and boot stripe are both similar colors (dark blue), so white underneath the raised bottom paint would make any scratches very visible indeed. Do 'they' make primer in blue?
I'm sure the answer to this question is somewhere on sailnet, but I could not find it (I'm not too good with searching online).
Lantau is offline
post #24 of 24 Old 03-05-2016
Senior Moment Member
SloopJonB's Avatar
If the existing stripe is gelcoat then no more prep is required than on the boats bottom - sand it, tape it, paint it.
SloopJonB is offline
Waterline paint question: How to factor in provisioning weight? chrisncate General Discussion (sailing related) 12 01-13-2011 10:22 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 09:24 PM
Painting the waterline stripe T26Rich Gear & Maintenance 3 04-22-2009 06:40 AM
What paint below the waterline on a hard dinghy? TaylorC Gear & Maintenance 2 04-20-2009 06:44 PM
Paint for boot stripe? poltergeist Gear & Maintenance 3 03-04-2008 01:38 PM
