Like Tree5Likes
Old 09-22-2011
asdf38's Avatar
asdf38 is on a distinguished road
Don Casey: Paint Waterline Stripe with Bottom Paint
I remember reading this suggestion and liking it in one of Don Casey's books. My waterline is a bit too low (perhaps 1/4 to 1" above the real waterline. Is this common for Contessa's?) and with the wave action I get at my mooring there is lots of growth and years of cleaning the growth off means the waterline paint job looks terrible and needs some attention.
This seems like a reasonable way to reduce my future maintenance. Obviously it wouldn't look quite as nice as shiny top-side paint but it would stop the growth and dealing with bottom paint is so much easier.
Currently I have Interlux topside paint for the waterline and ablative bottom paint. I assume if I did this I would put a hard anti-fouling paint on for the stripe? Any issue with this that I'm not thinking of? Would there be extra prep going from top-side to anti-fouling? Or other suggestions?
1979 Contessa 26
Boston, Ma
Old 09-22-2011
Great Lakes Sailor
padean is on a distinguished road
Are you talking about painting a strip a couple of inches above the current top of your bottom coat?
I have heard of painting the bottom coat a little higher to reflect wave action etc and keep growth off the gelcoat of the sides, but painting a stripe a few inches above the current waterline will still leave those few inches of exposed gelcoat.
I guess another possibility, which I have seen on several occasions, and used once on a boat I race on, is to stop the bottom coat at the current location, paint white bottom coat pain (such as Vivid) just above this for another inch or two. Then you could paint a stripe above this. Maybe that would help with what you are asking about.
PDean
CS 34
Saginaw Bay, Michigan
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
Old 09-22-2011
SecondWindNC's Avatar
SecondWindNC is on a distinguished road
The boatyard here has started using bottom paint for the boot stripe, and it seems to have worked pretty well on the boats I've seen. Not sure whether they're using ablative or something harder.
Carolina Wind Yachting Center Charter Manager
Who is staring at the sea is already sailing a little.
Old 09-22-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
In a moment of new boat owner confusion, the previous owner of a boat I owned painted bottom paint up to the BOOT Stripe. Yup, gritty blue paint all the way to the rubrail.
My Bristol 27 squats down in the back too. Would probably be worth trying to get it to sit on it's lines. Still, I like that idea.
Old 09-22-2011
mikel1 is on a distinguished road
Did I just read that first part right?
Old 09-22-2011
asdf38's Avatar
No, my bottom paint touches the waterline stripe, no gap in between. And as I said, the waterline stripe is at the waterline (or no more than 1" above it) and is topside paint so it's wet all the time and fouls up quick. I thought a quick scrub would remove the growth. I was wrong. That stuff is on there pretty solid. I guess it has to hang on to survive.
Wait is Boot stripe the same as waterline stripe? I may be confused on that point. But this sounds like exactly what I meant.
1979 Contessa 26
Boston, Ma
Old 09-22-2011
SHNOOL's Avatar
SHNOOL is on a distinguished road
Sorry ASDF, but I think you are confusing terms... See here http://www.sailnet.com/forums/gear-m...necessary.html
Mine is a different animal (small boat in comparison), but I have anti-foul, then gelcoat, then bootstripe then gelcoat... is this unique?
see below:
Oh this is the day I brought her home, she's much cleaner, has a new bottom, and the trailer looks better now.
Old 09-22-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
I believe you meant COVE stripe - the boot stripe is the coloured line above the bottom paint at the waterline.
My preference is to have the boot stripe several inches above the actual, static waterline and to bring the bottom paint up to the underside of it. Colour choice for the bottom paint becomes a bit more significant than if it's kept below the real waterline since it shows more but with careful choice it can look very good.
The actual extra height is dependent on the size of boat of course. I brought it up 2" on my 26' Quarter Tonner but I've seen it approaching 6" on a 42' boat. It also seems to look better if one has a wide or elaborate boot stripe - several stripes, stripes varying thick to thin etc.
It also serves to visually lower very high topsides.
If you have no other choice - gel coat boot top right at the waterline for example, then overpainting it with bottom paint would work but it would look a LOT better to repaint the boot top higher with gloss paint and then do the bottom as I have described. That line is second only to the sheerline in importance to a boats looks.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 09-23-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
I am trying one more time with conventional boot stripe paint but if I get the same degree of algae growth on the boot stripe I will try Petit Vivid next year.
From ELEPHANTS CHILD
And yes the boot stripe is/was bright red. 8 weeks in Clarks Court Bay Grenada did that.
Old 09-23-2011
tommays's Avatar
I have always raised my waterline to level that handles the splashing as a stripe of bottom paint that gets a bit wet is IMHP not going to look that nice
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Waterline paint question: How to factor in provisioning weight? chrisncate General Discussion (sailing related) 18 01-13-2011 09:22 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Painting the waterline stripe T26Rich Gear & Maintenance 3 04-22-2009 05:40 AM
What paint below the waterline on a hard dinghy? TaylorC Gear & Maintenance 2 04-20-2009 05:44 PM
Paint for boot stripe? poltergeist Gear & Maintenance 3 03-04-2008 12:38 PM
