Like Tree5Likes
Old 09-23-2011
fcsob is on a distinguished road
Ancor LED bulb
This bulb is a single contact bayonet basr with 12 leds. It is in a new fixture in the head. I seem to get about 30 to 50 hours of service from them before on led starts to blink then two ect. I have replaced it three times, warrenty,one shiped from Ancor. Any ideas?
Old 09-23-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Bad contact, causing resistance and voltage drop. Could be in the fixture, or the wire to the fixture. Low voltage is compensated by an increase in current draw, and heat as a byproduct. Increase in heat, causes further voltage drop, and current draw. It's a vicious cycle until the heat cooks the magic smoke out of the LED.
Old 09-23-2011
Don Radcliffe
donradclife is on a distinguished road
Don't think so--study Ohm's law and try again.
Old 09-23-2011
eherlihy's Avatar
Very constructive.... I am sure that the OP values your input.
You've earned yourself an addition to my ignore list...
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 09-23-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Touchy, touchy....
How about both of you expanding a bit as to WHY others are right or wrong before you snipe at one another? After-all, this ain't the OT or PRWG pages.
However, loss of the factory-installed smoke is pretty highly correlated with electronics failures.
Old 09-23-2011
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Don, not so helpful, that, and flat wrong to boot. While your advice applies quite nicely to the simple, standard incandescent light bulb, the LED light is a semiconductor device that resides on a circuit board with a voltage regulator.
Mr. Herlihy has it right - the circuit tries to maintain constant output of light. It compensates for low voltage with additional current to deleterious effect. For semiconductor devices, too much current is their worst enemy. The power absorbed (R*I**2) across the high-resistance junction generates more heat per second than it can dissipate per second, which melts the junction. Thus ends their useful life.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 09-23-2011
Maine Sail's Avatar
The LED's from Ancor are a very cheaply made product, likely made with very inexpensive ballast resistors and cheap orphaned emitters. Quality bulbs will use a DC/DC constant current regulator to feed the emitters what they need for a long life.
I highly doubt the Ancor bulbs have the circuitry or heat sinking to keep the emitters at a temp they like.
You might try a factory made LED nav light built for the purpose from the likes of Hella, Aqua Signal or others..
dacap06 likes this.
______
-Maine Sail / CS-36T
Old 09-23-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Yeah, so there!
It's 5 o'clock somewhere:
Old 09-24-2011
Egads! Thanks for that info, Maine! I don't have personal experience with Ancor and didn't realize the company didn't do a proper job of designing support circuitry.
Ugh. How do people like that stay in business? As soon as clientele catch on their sales should plummet.
Tom
T. P. Donnelly
Pasadena, MD
Old 09-24-2011
xymotic is on a distinguished road
]boy, that's a lot of big words. I'm not sure I understand completely, but I think you're saying the magic smoke got out? could't you just use the Internet tubes to pump more in?
dacap06 likes this.
Ancor Terminals: the must haves geary126 Gear & Maintenance 26 04-14-2012 08:22 PM
Ancor vs. 3M heat shrink adhesive connectors? turfguy Gear & Maintenance 39 05-04-2010 07:20 PM
bulb bow skomani Boat Review and Purchase Forum 2 10-01-2009 06:51 AM
Ancor wire tracker Grigrigrigoris Gear & Maintenance 6 04-05-2009 07:18 AM
Buying an ancor from a neighbor... MedSailor Gear & Maintenance 2 06-13-2008 09:20 PM
