Ablative bottom paint to VC-17 - Page 2 - SailNet Community
post #11 of 22 Old 10-04-2011 Thread Starter
I called around and got a few quotes on the soda blast, the best one came in at $2800.
Thats about 3X what I was expecting, so I started looking for an alternative.
There are a couple of products from Peel Away
Peel Away Marine Safety Strip - 5 Gallons
Peel Away Marine Strip - 5 Gallons
No solvents, no fumes, environmentally safe, wont damage the gel coat, blah blah blah.
One looks like it will take the surface down to the gel coat, the other looks like it will leave the barrier coat intact.
The video states that if applied and pressure washed off, the process takes about 4 man hours to complete on a 40 foot boat. That sounds peachy, but I dont believe it.
Anyone ever use this stuff?
The reviews Ive read have been good, but they are few.
Thinking about using the stuff that leaves the barrier coat. Strip the old bottom paint this fall and fair any place that is undamaged and dry, but needs it. Let the rest of the hull dry out through the winter, fair whats left, scuff sand, and apply a couple of barrier coats next spring.
Any better ideas?
Tweegs is offline
post #12 of 22 Old 10-04-2011
4KSB driver.
SHNOOL's Avatar
I will be watching this thread closely. while I just have a tiny 22 footer, the ablative to VC-17 is exactly where I am going. I bought Interlux Strip 299E, which is also supposed to remove the garbage.
I will start a separate thread here, and post pictures if I accomplish anything with it. I am fully planning on having to sand as well, then barrier coat, then VC-17.
SHNOOL is online now
post #13 of 22 Old 10-04-2011
A New Adventurer
funjohnson's Avatar
Anyone go the other direction...vc-17 to Ablative? I need to strip the vc-17 off because we are going to saltwater. Unfortunately, I cannot find any threads with anyone stripping the stuff off. The boat is still in the water and haven't yet tried to see how hard this stuff will be to sand off.
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
post #14 of 22 Old 10-04-2011
Yes, I have. It is very easy to sand off, particularly with a season's wear. However, you must get it all off. Nothing will stick to it. Pettit used to say some of their paints were compatible, but they seem to have retracted that position.
I have been told that it will actually wipe off with some solvent. Can't recall which. However, I'm trying to imagine having solvent running down my arms all day.
Edit disclosure: I didn't do all the sanding, but was there for the test when we were deciding which way to go. Orbital sander took it off with no effort at all.
Jeanneau 54DS
Minnewaska is offline
post #15 of 22 Old 10-04-2011
Senior Moment Member
SloopJonB's Avatar
Why not just sand the ablative very nicely with long boards and fine paper - down to 400 wet. That will give you a very smooth bottom for next season. Next spring, launch it and let the paint continue to ablate, like it is designed to. The more it ablates, the less work you will have to do to prep for VC17.
SloopJonB is offline
post #16 of 22 Old 10-05-2011 Thread Starter
I will certainly take that into consideration based on what she looks like at haul out, but that would be the easy way out. Im just not happy unless it takes 3 times longer, is twice as difficult, and the aggravation level is 10 times higher to achieve the same result.
Honestly though, because we are racing the boat, Id like to get the bottom as drag free as possible. We found several large areas where the paint had flaked off when we hauled out last year and its probably time to strip it down and start over. I'd really like to see what is going on beneath that old paint anyway, just to make sure everything is OK.
Tweegs is offline
post #17 of 22 Old 10-05-2011
SloopJonB's Avatar
We must have been separated at birth.
post #18 of 22 Old 10-05-2011
Tweegs, I don't know you or your boat, but offer this only as gross observation. I've seen many casual race boats with their owners obsessing over the hull, all the while the sheets and sails are nearly blown out, improper for conditions, or misfit. I would want it free of growth, but getting every last bump out is the last thing I would worry about to be sure I was going as fast a I could. Maybe all else is squared away on your vessel.
Jeanneau 54DS
post #19 of 22 Old 10-05-2011
4KSB driver.
SHNOOL's Avatar
Lemme help... If your bottom looks like mine (yes that is me putting VC17 over ablative)... it held up for 2 months in the water (fresh water).. But the bottom is so rough it is tough to no start over. By the way, what you see in the picture is the result after 80 grit sandpaper sanding to try to "smooth it out" a bit.
post #20 of 22 Old 10-06-2011 Thread Starter
We had the sails cleaned last winter and the sail maker (Doyle) rated the main as in poor condition and the head sail (155 genny) in fair condition.
A 40 knot gust blew out the main for us early in the year and we replaced it with a Pentax sail (Mylar/Kevlar) with the S load tapes custom cut for the boat.
We ran the old genny all year knowing it wasnt helping us much, but I just put a deposit on a new 135, again custom cut for the boat and of the same material used in the main.
For both sails the sail maker was out to the boat taking measurements, plugging those numbers into the computer, and using a sail makers sage and savvy to come up with a size and cut well suited to the boat. In our case the new head sail will be a #2, with a #2 weight and a #1 cut. Well use the old 155 in really light air.
Well have good sails for next year, but another problem to be addressed is that 16 fixed 3 blade prop. A 2 blade folding prop will replace it over the winter, a rigid vang is also on tap.
We put on a new traveler and added Genoa lead tracks over the summer, so at this point all of the big performance robbers have been or will be addressed. That leaves the bottom.
The bottom needs work if only from a general maintenance perspective. I figure that as long as were doing the work anyway, we may as well slick her up for the race season.
My thinking is that if the boat can sail to its potential, then it is all about the crew sailing it to its potential, and we know we have a lot of work to do there.
I'll snap a few pics at haul out to give a flavor of what I'm up against, though I don't think I'm in as bad a shape as SHNOOL.
Tweegs is offline
bottom paint hard or ablative psherwin Gear & Maintenance 4 08-07-2011 08:53 AM
Recommend an Ablative bottom paint for FL??? SiXeVeN Gear & Maintenance 10 07-02-2009 11:21 AM
Pettit Ablative Bottom Paint Joel73 Gear & Maintenance 1 02-24-2009 05:39 PM
ablative or hard bottom paint? Patbarbeau Gear & Maintenance 11 07-29-2008 07:11 PM
Ablative Bottom Paint Lifespan jlmarra Gear & Maintenance 14 07-07-2008 05:14 PM
