Old 09-26-2011
regatta's Avatar
S/V Dreamer - Marieholm26
regatta is on a distinguished road
Too many holes in my boat how to close its?
Hello To Everyone!
I have a problem in my boat. Many holes!!! Drill here drill there.
The previous owner make the boat like swiss cheese
I want close some and one of those is very big !!
Someone try to repair it but with bad result as you can see on the picture.
My question is: how to close holes and maintaining the integrity and strength.
Thanks in advance!!!
Too many holes in my boat how to close its?-senza-titolo.jpg   Too many holes in my boat how to close its?-dsc01351.jpg
Old 09-26-2011
zboss is on a distinguished road
There is an excellent book called "This old boat" which covers just about every system and structure you may find on a boat. It's quite extensive. You may consider buying a copy as I have found it extremely useful.
Old 09-26-2011
mitiempo's Avatar
regatta
The proper, strong way to close a hole like that - I am guessing 2" to 3" in diameter - is as follows:
Grind a taper all around the hole top and bottom. The taper should be ideally a 12 - 1 bevel but you may not have enough room so make it as large as you can up to that amount. If the deck is not cored a puck of thickened epoxy will fill the middle section. If the deck is cored a circle of plywood can be used. Then circles of fiberglass cloth ( I would use 1708 biax both for its strength and because its thickness builds faster than with thinner materials) are added with the largest first, working to the smallest. Use epoxy for its better secondary bonding strength. Fair with epoxy mixed with a filler like West 407, sand smooth and paint.
The West Fiberglass Boat Repair and Maintenance guide can be downloaded here - scroll down a bit. WEST SYSTEM | Use Guides
Here is a diagram of what you are trying to achieve for strength and durability.
Brian
Old 09-26-2011
MarkSF is on a distinguished road
Don Casey wrote that, and also the Sailboat Maintenance Manual which I just bought. I'm really impressed, covers every aspect of boat maintenance I can imagine needing to know about.
Bristol 31.1
Old 09-26-2011
tommays's Avatar
It could be the picture BUT the furler does NOT look like it has a toggle ? which allows free movement as the head-stay flexes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-26-2011
mitiempo's Avatar
Good point - I missed that.
Brian
More holes in my boat? deniseO30 Gear & Maintenance 10 11-11-2009 04:13 PM
Santa Rosa Boat Yard Close Out sailingdog General Discussion (sailing related) 0 10-28-2008 07:12 AM
Do you close your seacoks when leaving the boat ? negrini Gear & Maintenance 40 06-25-2008 01:35 PM
How close to the wind can your boat sail? davidbusby Seamanship 6 03-27-2006 10:03 PM
Drilling and Filling Holes in Your Boat Sue & Larry Gear and Maintenance Articles 0 03-11-2003 07:00 PM
