Old 09-26-2011
L124C's Avatar
L124C is on a distinguished road
Scoring lines for the Boot stripe
I'm getting ready to paint my hull with two part Polyurethane. Don Casey recommends removing (sanding) the Boot stripe before painting the hull. He suggests scoring the stripe before removal so it can be repainted in the same place. In a picture, he appears to be scoring it with a knife.
Has anyone done this? If so?
I'm assuming he suggests removing it (mine is in good shape) because the Polyurethane will wick under any tape used to mask the boot stripe?
When you score the hull, wouldn't sanding the boot stripe off remove the score (unless you went deep). Somehow, taking a knife to my hull freaks me out a little bit. Kind of silly, but it does.
Anyway, thoughts from anyone who has done it?
Old 09-26-2011
tommays's Avatar
I measured from the rub-rail down to waterline every 12" and made a drawing as it was something i did NOT want to lose and the path tends to be funky
By the time you do the priming and topcoat it would be tough for a scribe mark to survive
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-26-2011
Minnewaska will become famous soon enough
Of course, this all assumes that nothing has changed the level of your boat since it was last painted. Anchor chain, dinghies, moved or expanded tankage, etc can all change it and you really need to re-shoot it.
Jeanneau 54DS
Scoring Software paulk Racing 5 03-23-2011 08:04 PM
Blisters above boot stripe hilbert Boat Review and Purchase Forum 2 07-27-2009 01:52 PM
Paint for boot stripe? poltergeist Gear & Maintenance 3 03-04-2008 12:38 PM
How to remove chalk on boot stripe? chuck711 General Discussion (sailing related) 14 02-21-2008 07:57 PM
New Olympic Scoring Format paulk Racing 0 11-17-2005 06:58 PM
