Switching Batteries - SailNet Community
post #1 of 3 Old 09-26-2011 Thread Starter
Switching Batteries
A couple of years ago I fried an alternator by switching from the starter to the house batteries while the engine was running, even though I went thru "both". Before replacing the switch which could be faulty, I, since then, start the engine with the switch set on "both". It has worked well for me so far.
Now that I've retired and will anchor for longer periods (on house battery only) I'm wondering; if the house batteries are too low, placing the switch on "both" position will level the power between the house and starter batteries before I get the engine running? and therefore leaving me without enough power to start the engine.
For the record; I have two 6V = 12V for house and one 12V for starter. It's obvious that electrical is foreign to me, so please KISS.
Tank you for any feedback.
SV Strudel, Niagara 31
Not all who wander are lost.
anderbra is offline
post #2 of 3 Old 09-26-2011
Maine Sail's Avatar
KISS = Just start your engine and do everything on the house bank.
You have plenty of juice there to do that so long as you're not dropping the bank below 50% state of charge. This is much easier than constantly switching back and forth..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 3 Old 09-26-2011
HI Andr
on my bene 390 I have the alternator charg going to the start battery and then i have a battery disconect switch which connects the house bank.
When i want to put charge in the house bank i just connect the banks together with the switch. in this way the alternator can never get disconnected. This way is simple and reliable but you do have to remember to turn the switch off when you shut the engine off.
Mitch
mitchbrown is offline
Switching shore power from 220 to 110 JohnManzano Electrical Systems 4 06-25-2009 05:18 PM
Switching from power to sail dergon Boat Review and Purchase Forum 48 04-01-2009 07:29 PM
New Member - switching from mono to cat twinsdad Introduce Yourself 0 03-02-2009 10:31 PM
Switching head TXS-ALAMO Gear & Maintenance 14 08-28-2006 03:23 PM
Switching Batteries Tom Wood Gear and Maintenance Articles 0 04-10-2002 08:00 PM
