Old 09-28-2011
Junior Passage Maker
mikefossl is on a distinguished road
Outboard Prop
I have a 8ft Achilles air floor dinghy with a 5 HP 2 stroke outboard. It get's up on a plane pretty well with just me but when we have 2 plus the dog it can only plane on totally flat water (with bit of a tail wind). I've already changed from the standard 8" pitch to a 7" pitch prop but have found out that a 6" pitch prop is available. According to the prop calculations my top speed would be reduced to 12 knots from 15 which I'm not to worried about if I can get up on a plane with a bit of a load.
Old 09-28-2011
tommays's Avatar
The 6" high thrust prop which i have is really to allow the motor to reach RPM on a displacement hull and while it will move thousands of pounds it will NOT go fast
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Prop Guard for dinghy outboard Kiltmadoc Gear & Maintenance 7 06-23-2011 11:45 AM
Outboard prop is always spinning. It that bad? knotaloud Gear & Maintenance 13 07-12-2007 06:28 PM
Folding Prop for Outboard? Quickstep192 Gear & Maintenance 1 05-31-2007 10:41 AM
Best prop for a Catalina 27 and Honda 100 outboard monroe Catalina 0 08-16-2006 01:06 AM
Feathering Prop for Outboard Quickstep192 General Discussion (sailing related) 1 10-26-2002 06:52 AM
