fresh water tank repair - SailNet Community
post #1 of 7 Old 09-03-2003 Thread Starter
I have a hairline crack in my starboard fresh water tank. I can get to it through top access. The tank is glassed in so I can''t remove. What type of cement can I use to seal it? How should I prepare it. It is plastic.
averdog is offline
post #2 of 7 Old 09-05-2003
Often, freshwater tanks are made of polyethylene, a very difficult product to repair. I’ve not found anything to stick to it. Judiciously applied heat, may “weld” the crack, but (this too) is difficult.
Look forward to hearing from anyone with a “magic” bullet (glue - solvent cement) for poly’.
Regards,
Gord
GordMay is offline
post #3 of 7 Old 09-05-2003
We made reasonable (three year) repairs to the cracks in the bottom of a polyethylene ''Sportyak'' dingy with hot-melt glue. After laying down the bead of glue with the gun, a heated soldering iron (the old fashion nonelectric, solid copper soldering iron) was used to fair the edges to avoid abrupt changes in thickness. Be sure to soften the base material with the hot, metal tip of the glue gun to assure adheasion, then be very careful with the soldering iron and keep it moving during the smoothing. It would be quite easy to undo your good work! Regards, George.
geohan is offline
post #4 of 7 Old 09-05-2003
I''d strongly recommend grinding the tank out and getting something stronger.
But having said that, has anyone tried a petex candle? If not familiar with them, it''s a white plastic candle that you light conventionally and let drip on clean plastic. It''s used to patch show skis. Tough stuff.
soapstone is offline
post #5 of 7 Old 09-05-2003
do you mean p-tex? the stuff used to repair the bottom of skiis?
hamiam is offline
post #6 of 7 Old 09-13-2003
I had a similar problem with my tank and I used a product called J B Weld. Tape off the area then sand thoroughly to roughen the surface then apply. You have about 3-4 mins. of work time once the two parts have been mixed. Worked great.
tonyod is offline
post #7 of 7 Old 09-14-2003
I saw a plastic water tank plastic welded a few weeks ago in a CD-40 in Bass Harbor. Water was overfilled and split the tank while filling. Not too many outfits do the plastic welding. This guy is . . . Eaton''s Welding in Stonington Maine. I know, useless to you, but I also had him weld a 3/8" plastic replacement tank, with baffles (ss edge screwed) to replace my pinholed 32 year old stainless tank. It was less than 1/3 the cost of stainless replacement, and appears very tough. I had some custom measurements so I could drop it into a locker, position it, add the fittings and strap it down in the old tank beds. He got it to me in 2 days. Elegant. So I''ve looked into the welding gear. See www.malcom.com in Rhode Island. About $6,000 for the starter kit, and it''s not a plug and play type of operation. Some talent required. KW
VIEXILE is offline
Osmosis in integral FG water tanks sailawaysteve Gear & Maintenance 4 11-28-2007 10:10 PM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 06:26 AM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
water tank repair sleeper123 Gear & Maintenance 0 12-23-2000 12:21 PM
