Old 09-28-2011
xluke is on a distinguished road
water bladder cleaning and manual pump repair
Hello,
First, I have a water bladder that has had stagnant water in it for a while and I'd like to flush it out and clean it -- what is the recommended procedure for doing this? I presume some concentration of clorox but I'm open to any suggestions.
Also, I have a manual hand pump at the sink that isn't working (the galley sink doesn't work but the bathroom does, so I do not think it is a plumbing pressure issue). Is there anything that can go wrong that can be repaired with a manual hand pump faucet? I already took the bottom off and found a small rubber "valve" that appeared to be in good shape. I flipped it over and it didn't change anything...
When I pump it it seems to just move the water back and forth in the clear plastic line from the bladder to the sink, like it isn't holding the vacuum.
Thanks!
Old 09-29-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
C-Brite or B-Brite are commercial cleaners/disinfectants restaurants use and work well.
A winemaking supply shop will have them.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 09-30-2011
celenoglu's Avatar
celenoglu is on a distinguished road
"I already took the bottom off and found a small rubber "valve" that appeared to be in good shape. I flipped it over and it didn't change anything."
The same type "valve" should be also on the top. Check that one also.
Old 10-01-2011
Thanks for the tips!
Water Tank Cleaning and Pump Out ? thevdeub Gear & Maintenance 2 05-19-2010 11:56 AM
Water filter with manual pump faucet? IslanderGuy Gear & Maintenance 7 12-24-2009 08:06 AM
Water/bladder bag replacement dch Gear & Maintenance 4 02-25-2009 03:11 PM
Westerbeke 60 fresh water pump repair EdCraig Gear & Maintenance 4 06-29-2001 07:42 AM
