Butyl Tape and leaking port-light - Page 2 - SailNet Community
post #11 of 13 Old 09-30-2011
Maine Sail's Avatar
Originally Posted by MastUndSchotbruch View Post
Yes, I am glad you agree. In my situation it is hard to apply pressure which makes butyl an inefficient choice. Live and learn!
No one sealant is right for every application and you'd never catch me saying that.. Hell, I even recommend the dreaded silicone (AKA stupidcone) when appropriate.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 13 Old 09-30-2011
Some auto windshields are sealed with a butyl "rope" rather than a flat tape. Black, gooey, sticks and conforms and fills gaps.
I'd suggest a visit to an auto body or glass supplier, ask them about the butyl rope and about the urethane or other adhesives they use with it, to bond windshields.
You don't find the good stuff in RV stores or Home Depot.
hellosailor is offline
post #13 of 13 Old 11-24-2011 Thread Starter
Hello all,
Once again, thanks very much for the input for this thread. For anyone else contemplating a similar repair, the messages make an excellent "how to do it" work plan.
I would like to add a few points. My first attempt at it was unsuccessful because I didn't use enoughput tape and/or because there were pits and holes in the fibreglass cabin side. These weren't easily noticed but probably contributed to the failure of the first attempt. I removed the portlight once again (warming with hairdryer really helped), cleaned up, filled the pits etc. with gel-coat micro-balloon filler, smoothed everything and then reapplied the butyl tape at double thickness. I put one strip on the fibreglass around the opening and another one on the aluminum frame. Trying to add a layer of tape on top of another layer of tape was a little tricky as the tape sticks to tape very well and is difficult to move if you make slip during application.
Since it was quite cool on the day I was working (~45 degrees F. ), I used a hairdryer to soften the tape while I was re-applying the screws. Worked very well.
One warning about this kind of job is that if the inner frame screws directly to outer frame (not through-bolted) you have to make sure that you have enough tape at the joint that it will actually squeeze out the edges before the screws bottom out. This just barely happened to me and I think I would have been ok, in my case, with perhaps a third layer of tape, though it might entailed doing a lot more clean up afterward.
Cheers and thanks again for the help,
Ross
RossC32 is offline
Butyl Tape Question SailingWebGuy Gear & Maintenance 10 01-15-2011 09:33 AM
Question about butyl tape Survivor Gear & Maintenance 4 06-23-2009 11:49 PM
Where to buy Butyl Tape? sailak Gear & Maintenance 7 06-22-2009 10:27 AM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
Butyl tape underwater brak Gear & Maintenance 16 04-06-2009 05:29 PM
