Old 09-30-2011
Beersmith's Avatar
Sailing to surf
Beersmith is on a distinguished road
Butyl Tape for Bolts, ???? for screws?
I'm sold on using butyl tape to bed and seal all thru-bolted hardware on deck, including ports.
Do you use butyl for things that are simply screwed onto deck, such as teak trim or other non-load bearing items? It seems that the directions to use butyl always say to not turn the bolt heads, only the nuts so that the butyl remains set. But that is impossible for screwed in items.
If you don't use butyl for screwed in items, what do you use?
My boat rebuild/sailing blog:
Please read and provide comment to my entries!
Old 09-30-2011
dbruce85's Avatar
Ticon 30
dbruce85 is on a distinguished road
I did try butyl tape to rebed my genoa track, I had leaks on 5 or 6 of the screws.
Just backed them a bit, applied some Life Caulk and screwed them back down, it solved the problem.
I am now a believer that you should not turn the head after you apply butyl to get a good seal.
Old 09-30-2011
celenoglu's Avatar
celenoglu is on a distinguished road
To have a good seal you have to turn only the nuts. This is the rule for any sealing agent not only butyl tape.
Old 09-30-2011
Beersmith's Avatar
Sailing to surf
I understand that, but screws don't have nuts. what do you do about screws?
and before someone says "you shouldn't have screws, everything should be thru-bolted blah blah", please understand that there are non-load bearing things on deck, and some places where a bolt and nut would be impossible to secure due to inaccessibility.
Old 09-30-2011
mitiempo's Avatar
When an item is screwed to the deck the sealant (butyl or other) is between the deck and the item. All holes, for either screws or bolts, should have countersinks so an "O" ring of sealant is created where it is needed most.
Brian
Old 09-30-2011
rugosa's Avatar
rugosa is on a distinguished road
I've factory outfitted over 500 decks (mostly sail - production & custom, some power & 26 government commercial small vessels) and assembled decks to hulls on about the same. Best advise is test products, find the ones you like and 'stick' with them. After using Boatlife, 3M products and a number of others my #1 choices are 3M 5200 for permanent, 3M 4000 for future removal, butyl tape for thru-bolts (ALWAYS turn the nuts/not the bolts), clear silicone for removable teak plugs, silicone for wire feed holes for instrument displays because of the normally soft plastic housings.
ALWAYS counter sink all holes to clear the gel coat to avoid cracks radiating from the hole.
I've seen installers throw away those thin foam gaskets that come with some instruments and install them with with butyl tape. Looks nice on install day but always oozes in the heat. I prefer to use the manufacturers materials & advise (they invested in the research and field feedback). These are the same installers that throw away the manufacturer supplied instrument junction boxes and use an exposed terminal strip in a locker. Sooner or later there's gonna be trouble.
I almost always toss hardware manufacturer supplied fasteners and stick with my regular suppliers fasteners, lessens the risk of cheap fasteners and rust problems.
Old 09-30-2011
rugosa's Avatar
What year is your CS27 Brian?
Old 09-30-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
While I use butyl for some things, it's not for everything...
For big things tha are through-bolted--winches, ports, tracks--it can't be beat. It makes it simple to remove the item later and does not harden.
However, I've used it for screws and been disapointed. Part of the problem is the twisting. However, for small parts I like the adhesive quilities of 5200. If I install a small pad-eye or a guard rail for a heater stack, the extra bond of the 5200 keeps it tight and it will come off easily enough later anyway.
My personal feeling is that unless I can through-bolt, I'm better off with an adhesive. Large items, like ports that are screwed on, I may still go with butyl (the hatches on my boat were screwed on and factory butyl, and were still well sealed and tight after 14 years). But sometimes you need to look at each application and make a judgment.
Other than difficult removabilty, the other weakness of 5200 is that it doesn't keep in the tool box. Even with foil under the cap, 3-4 months seems to be the limit. And so I occationaly use butyl where I should not, simply because I always have it. If it's that or silicone, I know it will be easier to remove the butyl later.
Rugosa is dead on, except I question the foam gasket preference on some occations. I can't even remember how many of the those gaskets have failed and leaked over time in both marine and industrial settings, ruining something. I think I would take that case-by-case; some are good, and some are clearly crap. As for the ooze, it never really bothered me, but I'm quite certain it would botter some customers. Perhaps my climate is cooler.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 09-30-2011
Maine Sail's Avatar
I have some tricks for this but have been reluctant to share them as the technique is critical and even with my in-depth instructions people still don't follow the instructions as well as they could..
I do seal screws with butyl and it works great for ME but for most folks I would advise a marine sealant as it is easier and less dependent upon the technique used.
______
-Maine Sail / CS-36T
Old 09-30-2011
Beersmith's Avatar
Sailing to surf
what sort of marine sealant would be used for non-load bearing deck fitting? 5200/4000, polysulfide, silicon?
Heating butyl tape? farwesthoops Gear & Maintenance 2 04-29-2011 05:46 PM
Question about butyl tape Survivor Gear & Maintenance 4 06-23-2009 11:49 PM
Where to buy Butyl Tape? sailak Gear & Maintenance 7 06-22-2009 10:27 AM
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
Butyl tape questions. baboon Gear & Maintenance 11 12-09-2008 10:10 PM
