10-02-2011
Senior Moment Member
Originally Posted by jimmoser
Hatch cover location makes it likely to get stepped on. Would balsa be strong enough?
Most decks are balsa core - I'd use foam core because it won't absorb water if the lamination gets breached in any way. If you buy the pre-scored foam it is much easier to fit than plywood because it can "droop" into the shape of the hatch. Set it in thickened epoxy and glass over the underside with a suitable number of layers of glass. It will be better than new.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
