10-02-2011
You would need to follow the wiring to the breaker panel and out to the various devices that the AC will power...
you will want to purchase an outlet tester (if you do not have one) at a minimum as AC and boats (water) can provide a very unforgivable combination if not installed properly. At a minimum the boat should have, or you should have installed prior to use, GFCI protected outlets.
Most likely a boat that size will have some sort of battery charger and at least one battery, perhaps two. If it does not and you desire one, please get a "marine" battery charger as the autozone/auto parts style are not safe for boat use.
