Old 10-03-2011
Scott Vickery is on a distinguished road
Best finish for Ash
I just built a new tiller out of Ash. Now I need to finish it. The 2 ideas I have so far are: 1) Stain and then tounge oil, 2) Stain and then varnish. Any thoughts or recommendations?
Thanks,
Scott
Old 10-03-2011
kd3pc's Avatar
kd3pc is on a distinguished road
you may want to stain or tung oil....not both, as they may not be mutually agreeable and one may interact badly with the other...
tung only or,
stain only
Similarly with stain and varnish...one usually stains and "seals" or varnishes, as the varnish will likely not adhere well to a truly stained finished. There are products to use with stain, to achieve similar finish
Old 10-03-2011
Sabreman's Avatar
Sabreman will become famous soon enough
Why stain? IMO, it destroys the beauty of ash.
Tung Oil is not an exterior finish. I highly recommend using a spar varnish like Minwax Spar Varnish (which is actually a urethane as are most "varnishes" today). Apply about 10 coats. It has UV protection and is flexible to allow for the inevitable contraction/expansion due to temperature and humiodity. However, NO finish is totally impervious to the elements and requires replenishing at least yearly. I would make a sunbrella sock to protect it, removing the tiller and storing inside during the off season.
Sabre 38 "Victoria"
Old 10-03-2011
Sabreman's Avatar
kd3pc is right. If you insist on staining, be VERY careful regarding the type of stain.
Sabre 38 "Victoria"
Old 10-03-2011
Thanks for the replies. My thought behind stain was so the tiller would more closely match some of the other woods on the boat which are not natural. So, it sounds like I should either do the Minwax Spar Varnish OR a stain and seal.
Scott
Old 10-03-2011
Sabreman's Avatar
Minwax Spar Varnish. More traditional look and really tough. I use it on my cabin floor and all the high wear areas inside.
Sabre 38 "Victoria"
Old 10-03-2011
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
I was told my window panels are African Ash? I used West 207 epoxy to seal the wood, and then varnished over it......i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 10-03-2011
MarkSF is on a distinguished road
Scott
My Wayfarer had teak benches that needed refinishing. Some areas were dark and some very light. I stained them with a medium wood stain bought from Home Depot and then 5 layers of spar varnish. The results were absolutely fantastic. The boat also had an ash tiller stock that the previous owner had stained to match the teak. Looked good too.
My suggestion would be to get an offcut of the ash, and experiment with the stain until it matches your existing wood. I found if you soak a tissue and then rub the stain into the wood, it is much more controlled than brushing. With the tissue you can add several thin layers until the wood is dark enough. With brushing it just goes really saturated with the first coat.
When I get home I can post a pic of the re-finished benches.
Bristol 31.1
Old 10-03-2011
kd3pc's Avatar
second vote for Minwax Spar Varnish....even a novice who can read can get awesome results....just be careful polishing it..I once used some pledge on a newly done compass rose floor inlay...and it was so slick you could not walk on it in stocking feet...it held up very well, and still is.
Old 10-04-2011
Chris12345 is on a distinguished road
I would not stain it, because dings and scratches would show in the original color, which looks bad, imo.
Solid wood with dings and scratches will still look ok.
Also, repairs will be easy, because you can patch just the damaged spot.
Thanks,
Scott
Teak finish H and E Gear & Maintenance 15 10-02-2011 11:41 PM
How do you re-finish teak? KeltiC SailNet FAQ's 12 08-08-2010 08:40 PM
Valiant 40 finish.. CharlieCobra Gear & Maintenance 14 05-13-2010 01:21 PM
Keel finish JimTschet Gear & Maintenance 5 04-05-2010 06:11 PM
Right of way at the finish? noscreenname Racing 16 07-12-2006 10:53 AM
