10-03-2011
Originally Posted by Barquito
Is glassing over the hull to deck joint an effective way to prevent leaks, and strengthen the boat? If it is, then why are boat not made that way in the first place? I'm looking at a bazillion bolts to rebed this winter under the toe rail. Maybe glassing over them all would be more perminant solution.
Ericson Yachts did that on most of their boats. It's very strong and leak proof, but does add another bunch of labor cost to the build. Their boats have a band of heavy roving on the inside, joining the deck and hull. Quite a few limited-production and custom boats are built that way.
Strictly "IMHO" but the next best method is to have the hull top end in an inside flange, with the deck attached by thru-bolts and nuts. Our boat is built that way, with the slotted alum. toe rail on top. This later system also required a take-apart mold - again, a bit more labor. My previous Niagara was build that way, too. No leaks, no problems.
LB
