10-06-2011
Junior Senior
If your boat is trailerable, it probably has a bow eye. Make sure that the bow eye is bolted in securely and well backed up, then use the bow eye as the primary mooring attachment point. This will eliminate the number one cause of pendant failures: chafe. Then use a longer line as a back-up going to your bow chocks/cleats. I use different colored lines to make them easily distinguishable.
I use a 3/4" braided nylon line with a thimble spliced into each end as my primary pendant. It is attached to the chain at the bottom of the buoy with a regular shackle; I hook it to the bow eye with a 1/2" SS quick link. My back-up pendant is also braided nylon, 5/8" diameter, and about 3' longer than the primary. It has a thimble spliced in at one end and an eye for the bow cleat at the other. I slipped some sections of a "pool noodle" over portions of it before I did the splices so it would float. (Of course, you can buy purpose made mooring pendants that float.) This let's it serve as a pick up line. I grab this with the boat hook when approaching the mooring and slip the eye over the bow cleat. It holds the boat securely until I'm ready to go ashore. Then I hook up the bow eye pendant from the dinghy as the last thing I do.
This system has worked well for me for over 20 years. But then, I'm only a lowly lake sailor.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
