Like Tree4Likes
Old 10-06-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Bahamian Mooring
I am seeking opinions on using a Bahamian mooring instead of a conventional huge block of concrete for a summer mooring for a 43', 11 ton boat.
What I have in mind is using two BIG anchors - 150# each or so, linked by chain with a chain shackled from the middle of the span rising to a buoy. The proposed mooring spot is reasonably sheltered but the wind CAN blow and the seas can reach maybe two feet.
My reasons for wanting to do it this way are twofold - I don't want place an essentially permanent lump there and I would like to do it myself, not requiring a barge, crane etc. and the purchase of the aforementioned lump.
I figure I can pick up a couple of decent big anchors for less than the lump would cost and they are retrievable relatively easily when the time comes.
Thoughts?
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 10-06-2011
Gene T's Avatar
Gene T is on a distinguished road
First thing that comes to mind is are you planning to set the anchors, or just drop them in place. Also anchors need scope to work properly. Are you planning to use the appropriate scope? It would certainly work if set and using proper scope.
Gene
Currently in Long Beach, CA
Old 10-06-2011
klem is on a distinguished road
I would advise against using a bahamian mooring setup as a permanent mooring. If the wind blows perpendicular to how the anchors are laid out, you can end up with very high loads on the anchors unless you have left a lot of slack in their chains and then you end up with changing directions of pull.
If you are set on doing a multiple anchor setup, a 3 point setup works well if setup properly. Getting the ratio of chain in the legs to chain in the leader from the legs to the ball right is very important. Additionally, getting the correct amount of slack in the chains is key. Believe it or not, you need some slack or you will greatly increase the loads on the anchors because they will be reacting against each other. Also, you need to have a good way of attaching everything that will not twist up. When properly done, this provides excellent holding power but when improperly done, loads can be greatly magnified or direction of pull on the anchors can change a lot. I would highly recommend drawing out free body diagrams and figuring out how much load is on each point for given geometries if you decide to go this way. Doing this will help a lot in figuring out what the geometry should be.
What is the bottom where you are? If you have sufficient tide and the bottom is decent, you can move an appropriate size mushroom or pyramid with your boat as long as you are careful. By driving the gear down to the low tide line and then coming over it with just a little tide left to do the final lifting, you can use the boat's buoyancy to pick it up. Just be careful to rig it so that you can lower it in control down to the bottom.
Old 10-07-2011
Windborn is on a distinguished road
Can you use screws?
Our mooring consists of 5 screws linked with heavy chain. A 20' chain connected to the screw's chain has two 3/4" pendants that come up to the boat. We've survived hurricane hits with this setup.
Old 10-07-2011
Windborn,
Out of curiosity, do you have a wave of equalizing the load on your screws? I am not a fan of most multiple anchor moorings because there is not load equalization and you can pull out each anchor one by one. There are ways obviously to deal with this but I have rarely seen it effectively done.
Old 10-07-2011
SloopJonB's Avatar
Gene
I had thought to set them, one at a time, facing each other with a length of chain equal to proper scope across. I figured the pull from a near vertical chain in the middle would have a vector that would try to pull them together rather than up (basically).
The bottom is is mostly rock and shale. I had planned to have a diver check the set of them prior to use.
Old 10-07-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
I think Bene505 uses a multi[ple anchor system to moor his boat at Montauk. You might PM to get his experiences.
Old 10-07-2011
MastUndSchotbruch is on a distinguished road
screws?
Originally Posted by Windborn View Post
Can you use screws?
Can you be more specific? Helix anchors (TM) or something else? How did you get them in? What kind of situation (bottom, exposure, boat size)?
Thanks for any information on this. I am considering getting a mooring set-up for a hurricane situation.
Old 10-07-2011
paulk's Avatar
paulk is on a distinguished road
Our harbor uses helix anchors for strings of 6 or more boats. In the recent Hurricane/Tropical Storm Irene, the main concern was not that they would pull out, but that boats would be held down by their anchors and sunk when the water rose over their gunwales. We're talking 30 to 40 foot cruising keelboats - not daysailers. Crews went around lengthening the mooring lines to accommodate the extra four feet or so of water we got at high tide that day, and nothing happened.
Old 10-07-2011
With your center-chain pull I wonder if you wouldn't have some very high loads on the system if you ended up pulling hard at 90 degrees to axis of the two anchors.. (similar to how a crosswind in a stern/shore tie situation can put heavy loads on the hook)
btw.. where are you going to try this??
1984 Fast/Nicholson 345
Duarte Marine Makes Mooring Easy, Debuts First Single-Handed Mooring System - PR Web NewsReader News Feeds 1 10-06-2011 01:58 PM
Using a snatch block for a Bahamian Moor labatt General Discussion (sailing related) 12 04-09-2009 06:22 PM
