How much zinc is enough? - Page 4 - SailNet Community
post #31 of 37 Old 10-17-2011
Dirt Free
boatpoker's Avatar
The original point I was trying to make (apparently not well) to the OP was that this is an extremely complex issue and that free advice is worth what you pay for it. Unless one has certification in marine corrosion or NACE training, free advice from shade tree electricians can be costly and on rare occasions deadly.
This is my last word on this subject.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #32 of 37 Old 10-17-2011
I don't discuss my member
Fstbttms's Avatar
Originally Posted by boatpoker View Post
current in the water equals ..... current in the water.
Nothing either you or Rifkin has said provides the slightest bit of evidence of the existence of marina-wide corrosion issues. Again, I suppose it may exist, but in my experience, the term "hot marina" is just another one of those things that boaters talk about but don't really know about. And that is a term I hear bandied about all the time. In 17 years of replacing zincs on boats in virtually every Bay Area marina, I have yet to see an honest-to-God "hot marina".
Fstbttms is offline
post #33 of 37 Old 10-17-2011
Fstbttms's Avatar
...free advice from shade tree electricians can be costly and on rare occasions deadly.
On this we can agree.
Fstbttms is offline
post #34 of 37 Old 10-17-2011
TQA
Bombay Explorer 44
TQA's Avatar
OK I have a lightish 30 year old 44 foot grp boat with the usual collection of thru hulls a large metal fitting at the base of the skeg hung rudder and a prop shaft with a P bracket.
When I bought the boat it came with a single doughnut zinc on the propshaft. This lasts a year although the one I have just taken off was ready to fall apart.
Is this enough ?
Should I fit 2 propshaft zincs ?
Should I fit a separate zinc to the rudder bearing at the bottom of the skeg.
TQA is offline
post #35 of 37 Old 10-17-2011
Fstbttms's Avatar
Originally Posted by TQA View Post
Is this enough ?
Two is a very common arrangement, is cheap insurance and almost certainly not going to over-protect the boat.
Unless you have found evidence of corrosion there, probably no reason to add a zinc.
Fstbttms is offline
post #36 of 37 Old 10-17-2011
Ok Lets jam a piece of carbon against a piece of stainless steel so tightly that even humidity cannot penetrate .... now we spin the stainless at 2800RPM......
I think you could sell that idea to Bic .... don't think Yanmar would be interested.
I am beginning to think you don't know what your talking/writing about!
Shaft Brush
2436 - Shaft Brush
http://www.mgduff.co.uk/pdfs/commerc..._Earthing_.pdf
http://www.engineersparadise.com/six...0grounding.pdf
foggysail is offline
post #37 of 37 Old 10-17-2011
TQA
Bombay Explorer 44
TQA's Avatar
Thank you. Two propshaft zincs it shall be.
TQA is offline
Other uses for zinc Bene505 Gear & Maintenance 17 02-07-2009 04:22 PM
More Zinc Please... DrB Gear & Maintenance 9 11-13-2008 01:22 PM
